    Feb 2009
    ORA-01552: cannot use system rollback segment for non-system tablespace
    I am trying to create a table in my Oracle 10g database and I get the following error:
    SQL> create table pbh.abc (a number(4), b number(4)) tablespace pbhtables;
    'PBHTABLES'
    When I in run show paramter undo in sqlplus here is my output.
    NAME TYPE VALUE
    undo_management string AUTO
    undo_retention integer 900
    undo_tablespace string
    This is what I have in my init.ora file.
    Can somebody please tell me what I need to do (include syntax) in order
    to rectify this issue.
    you havent created an undo tablespace, or if you have you havent set your instance to use it
