creat control file in no mount.
Results 1 to 7 of 7
Thread: creat control file in no mount.
    Feb 2009
    I want to recreate my control file.So I first start the instance in nomount and in nomount I gave script to create control file.It created control file in nomount.Now when I checked status from v$instance, it is showing mount.But in control file script there was no statement to alter from nomount to mount.Then how it happened.....?
    When we recreate control file.....in nomount state right..?
    My question is how it automaticaly converted to mount state from nomount even if there was no alter statement...?
    because someone or some script altered it
    Feb 2009
    No I am pretty sure no ome or no script cnaged to mount state.I fu want I can show u script
    Apr 2008
    Bangalore
    please post the script
    Feb 2009
    CREATE CONTROLFILE SET DATABASE "WIPP" RESETLOGS NOARCHIVELOG
    MAXLOGFILES 9
    MAXLOGMEMBERS 2
    MAXDATAFILES 88
    MAXINSTANCES 1
    MAXLOGHISTORY 226
    LOGFILE
    GROUP 1 (
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oralog01/log_g1_m1.dbf',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oralog02/log_g1_m2.dbf'
    ) SIZE 20M,
    GROUP 2 (
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oralog02/log_g2_m1.dbf',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oralog03/log_g2_m2.dbf'
    ) SIZE 20M,
    GROUP 3 (
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oralog03/log_g3_m1.dbf',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oralog01/log_g3_m2.dbf'
    ) SIZE 20M
    DATAFILE
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/system_01.dbf',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/rbs_01.dbf',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_wm_classinfos.data1',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_wm_maintenance.data1',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_wm_archivefs.data1',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_wm_cnc_filset.data1',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_wm_history.data1',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_wm_index.index1',
    '/Applied/data_validation3/DV_HD950250/hot/oracle/wipprd/oradata01/wipp_temp.temp1'
    Quote Originally Posted by tmgsam View Post
    Check alertlog.
    Mar 2006
    Charlotte, NC
    tmgsam -
    when you create the control file, oracle brings the instance to mount to do the sanity check.
    Vijay Tummala
    Try hard to get what you like OR you will be forced to like what you get.
