    Nov 2006
    Query showing tables/sequences
    Hi All,
    Can someone please help me with a query that can show all the tables & associated sequences within the same schema in an Oracle database?
    divroro12
    Mar 2006
    Charlotte, NC
    Hi Divro -
    I believe we don't have any views available to query the tables and associated sequences.
    The way i look is if the sequences are created with common naming method like TABLENAME_SEQ with that we can identify for which table that particular sequence is created.
    Vijay Tummala
    Try hard to get what you like OR you will be forced to like what you get.
    Nov 2006
    Vijay,
    All i'm trying to see is all the tables & sequences within the same query...
    divroro12
    Quote Originally Posted by divroro12 View Post
    Hi All,
    There is no association per-se in between tables and sequences so Oracle has no way to keep track of them
    This is the time when you should go to your design documentation and check the usage of each Sequence.
