    Apr 2007
    USA
    ORA-06502: PL/SQL: character string buffer too small
    All,
    I changed some datatypes from varchar2 to CLOB. Now a function throws up this error
    ORA-06502: PL/SQL: numeric or value error: character string buffer too small
    I have tried high settings for
    dbms_output.enable( 2000000)
    serverpout
    arraysize
    longchunksize etc to no avail.
    I understand there is a backend procedure (DBMS_?) that could help with this?
    Thanks for suggestions
    Looking for the greatest evil in the world? Look in the mirror.
    I'm not totally following you but, are you referring to DBMS_LOB?
    The error could be caused by nearly anything. Perhaps if you posted your code with the actual error stack, someone can help you with the error.
    Probably you have a varchar2 in the code that is too small. The error stack should give you a line number which should point to the variable that is causing the error.
    Apr 2007
    USA
    Thanks fellows. I stumbled over this and forwarded to the developer. It closely mirrors what his problem is...
    http://asktom.oracle.com/pls/asktom/...D:481421535472
