    Hi all,
    1) I have created a new database called 'oct'.
    The database was opened, however, I was not able to log into 'database' 'OCT' using sqlplus.
    a)Which user id and password, should I use to get into this new data base?.
    2). As I could not get into 'oct', I tried connecting back using the default 'ORCL' database after changing the ORACLE_SID to ORCL and all other parameters being same.
    Now, I am unable to get into even SVRMGR, Oracle gives
    ORA-12203: TNS:unable to connect to destination.
    I have checked up the listner(It's running) and all other files are in its place.
    Please advice
    Badrinath
    Sep 2000
    You could connect as:
    sqlplus system/manager
    sqlplus sys/change_on_install
    su - oracle
    $ svrmgrl
    SVRMGR> connect internal;
    you could try as well:
    sqlplus scott/tiger
    But the problem is, I am not able to get into svrmgr.
    when I give svrmgr30,
    I immediately get TNS: error.
    Can you please help me in starting one of the servers
    orcl/oct.
    The ORACLE_SID is ORCL and listener is running
    Badrinath
    Before you start Server Manager issue at command prompt:
    SET ORACLE_SID = ORCL
    Start Server Manager and connect.
    Nizar
