Output TAG
Hello,
Please help me with the following problem:
I wish to have Incremental level 0 with the default output format (tag) as specified from
RMAN> CONFIGURE CHANNEL DEVICE TYPE DISK CONNECT
'system/manager' FORMAT '/oracle_backup_mindses1/SMS_ora_%T_%s_%p';
BUT the incrementa level 1 to have an output format with a DIFF at the beginning and to the same path.
Mimas
I want that because I need to copy the weekly full backup after the first Differential because of disk space.
then I will leave the Differential for a week to take backup.
You could ALLOCATE the channel specifically prior to your backup command and specify the FORMAT.
