    Jun 2007
    listener problem
    i am having a problem with my listener which is as below
    C:\Documents and Settings\seyi>lsnrctl start
    LSNRCTL for 32-bit Windows: Version 10.2.0.1.0 - Production on 02-OCT-2008 16:11
    :51
    Copyright (c) 1991, 2005, Oracle. All rights reserved.
    Starting tnslsnr: please wait...
    Failed to start service, error 3.
    TNS-12560: TNSrotocol adapter error
    TNS-00530: Protocol adapter error
    C:\Documents and Settings\seyi>lsnrctl status
    LSNRCTL for 32-bit Windows: Version 10.2.0.1.0 - Production on 02-OCT-2008 16:12
    :26
    Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=localhost)(PORT=1521)))
    TNS-12541: TNS:no listener
    TNS-00511: No listener
    32-bit Windows Error: 61: Unknown error
    Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC1)))
    32-bit Windows Error: 2: No such file or directory
    The content of my listener is
    # listener.ora Network Configuration File: C:\oracle\product\10.2.0\db_1\network\admin\listener.ora
    # Generated by Oracle configuration tools.
    SID_LIST_LISTENER =
    (SID_LIST =
    (SID_DESC =
    (SID_NAME = PLSExtProc)
    (ORACLE_HOME = C:\oracle\product\10.2.0\db_1)
    (PROGRAM = extproc)
    LISTENER =
    (DESCRIPTION_LIST =
    (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521))
    (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1))
    and tnsname is
    # tnsnames.ora Network Configuration File: C:\oracle\product\10.2.0\db_1\network\admin\tnsnames.ora
    ORCL =
    (DESCRIPTION =
    (CONNECT_DATA =
    (SERVER = DEDICATED)
    (SERVICE_NAME = orcl)
    EXTPROC_CONNECTION_DATA =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (CONNECT_DATA =
    (SID = PLSExtProc)
    (PRESENTATION = RO)
    pls can someone help
    Mar 2006
    Charlotte, NC
    Change your listener.ora like this ... and start the listener.
    SID_LIST_LISTENER =
    (SID_LIST =
    (SID_DESC =
    (PROGRAM = extproc)
    (SID_DESC =
    (SID_NAME = orcl)
    LISTENER =
    (DESCRIPTION_LIST =
    (DESCRIPTION =
    Vijay Tummala
    Try hard to get what you like OR you will be forced to like what you get.
    Jun 2007
    i tried it but still not working
    Mar 2006
    Charlotte, NC
    what error it is throing this time? Is it same as above?
    Also can you please check whether you are able to do ping to ' localhost '?
    Vijay Tummala
    Aug 2007
    Cyberjaya,kuala lumpur
    Quote Originally Posted by vnktummala
    You tried this...?
    In the place of localhost give the ip of the server and try again.
    You set the oracle path,sid correctly.. right ?
    Thanks/Gopu
    Quote Originally Posted by gopu_g
    localhost always translates as 127.0.0.1, by design.
