Results 1 to 8 of 8
Thread: how to act in this situation?
    Apr 2008
    my database is ill-preserved one, it is now full of data and wat can i do? how can i move the contents into some other disk which is empty?
    Lake Worth, FL
    Cool Move the files
    Just follow normal procedure to move (relocate) the data files.
    Any one of these:
    1) Backup controlfile to trace, shutdown db, move the files, change locations in the "CREATE CONTROLFILE", starup nomount, create controlfile...
    2) Alter tablespace offline, move files, alter database rename files, alter tablespace online
    3) Shuutdown database, move files, add 'DB_FILE_NAME_CONVERT' to the init.ora file, ...etc...
    Apr 2008
    thanks a lot guru ...
    I'm confused, if the database is really "ill-preserved" then how it is "full of data"???
    I think he means it wasn't being managed properly.
    Do you use some kind of Logical volume manager ?
    Hrishy
    Oct 2006
    Mumbai
    Quote Originally Posted by hrishy
    Hrishy
    If Yes, u can resize the LVM disk online and create more space.
    Paresh
    Apr 2007
    USA
    i would like to know what ill-preserved means...
    Looking for the greatest evil in the world? Look in the mirror.
