Thread: help with IMP
    Jan 2008
    help with IMP
    Why do we get the following error? This import takes place every day and we have not changed it.
    We use the imp command.
    Connected to: Oracle Database 10g Enterprise Edition Release 10.2.0.2.0 - 64bit Production
    With the Partitioning, OLAP and Data Mining options
    Export file created by EXPORT:V10.02.01 via conventional path
    Warning: the objects were exported by LTR, not by you
    import done in US7ASCII character set and AL16UTF16 NCHAR character set
    . importing LTR's objects into LTRPROD
    . . importing table "COMPONENT" 4907 rows imported
    . . importing table "COMPONENT_DIFF" 0 rows imported
    . . importing table "COMPONENT_PART" 22374 rows imported
    . . importing table "COMPONENT_PART_DIFF" 0 rows imported
    . . importing table "COMPONENT_RULE" 359 rows imported
    . . importing table "COMPONENT_RULE_DIFF" 0 rows imported
    . . importing table "TEXT_VALUE_DIFF" 0 rows imported
    . . importing table "USER_SIGNATURE" 187 rows imported
    IMP-00017: following statement failed with ORACLE error 1031:
    "CREATE UNIQUE INDEX "USER_SIGNATURE_PK" ON "USER_SIGNATURE" ("USER_ID" ) P"
    "CTFREE 10 INITRANS 2 MAXTRANS 255 STORAGE(INITIAL 10485760 FREELISTS 1 FREE"
    "LIST GROUPS 1 BUFFER_POOL DEFAULT) TABLESPACE "LETTER_INDEX" NOLOGGING"
    IMP-00003: ORACLE error 1031 encountered
    ORA-01031: insufficient privileges
    . . importing table "WORD_DOCUMENT" 307 rows imported
    . . importing table "WORD_TABLE" 110 rows imported
    . . importing table "WORD_TABLE_HEADING" 472 rows imported
    About to enable constraints...
    Import terminated successfully with warnings.
    Feb 2004
    UK
    Do you have a tablespace called 'LETTER_INDEX' on your target database and do you have authority to create objects in it ?
    Is this the first time that the source database has had indexes ? and hence the first time that the import has tried to create any ?
    Jan 2008
    hey
    we run this script everynight and we have no prob with it... but for some reson it failed lastnight
    here is the script:
    imp $DBUSER/$DBPASS@$DB_INSTANCE \
    file=$DUMP_DIR/$LTRDUMPFILE \
    fromuser=$SOURCE_LTR_SCHEMA touser=$LTRUSER \
    grants=N \
    LOG=$DBERR_FILE statistics=none
    then
    drop user &1 cascade;
    -- Create the user
    create user &1 identified by &1;
    -- Grant the acccess
    grant connect,resource, create session, create synonym to &1;
    Something is wrong, that's for sure.
    By the way, your previous post is confusing, it looks like you attempt to Import "then" you drop the user, recreate it and grant privs.
    Is your script spooling to a log? Look around the grant privs statement, what is says?
    Jan 2008
    it is the other way
    -- Create the user
    here is the script:
    grants=N \
    and also have a look at this:
    vahx0106>$ pwd
    /u51/app/hqa/librarian/db
    vahx0106>$ ls -l ltr.dmp
    -rw-r--r-- 1 hqalibjl hqa 71116800 May 16 09:17 ltr.dmp
    How do i proceed from here on............
