Problem in setting archive destination for standby database
Thread: Problem in setting archive destination for standby database
    Apr 2007
    india
    Database version:10.2.0.1.0
    I am getting problem when i am trying to set log archive destination for standby database which is in the same system.
    The following parameter is set in parameter file:
    log_archive_config='dg_config=(primary,phstandby)'
    log_archive_dest_1='LOCATION=f:\oracle\primaryarch VALID_FOR=(ALL_LOGFILES,ALL_ROLES) DB_UNIQUE_NAME=primary'
    log_archive_dest_2='LOCATION=f:\oracle\standbyarch VALID_FOR=(ONLINE_LOGFILES,PRIMARY_ROLE) DB_UNIQUE_NAME=phstandby'
    LOG_ARCHIVE_DEST_STATE_1=ENABLE
    LOG_ARCHIVE_DEST_STATE_2=ENABLE
    FAL_SERVER=primary
    FAL_CLIENT=phstandby
    DB_FILE_NAME_CONVERT='f:\oracle\oradata\PRIMARY','f:\oracle\oradata\STANDBY'
    LOG_FILE_NAME_CONVERT='f:\oracle\primaryarch,'f:\oracle\standbyarch'
    STANDBY_FILE_MANAGEMENT=AUTO
    The archive list command shows online single archive location:
    SQL> archive log list
    Database log mode Archive Mode
    Automatic archival Enabled
    Archive destination f:\oracle\primaryarch
    Oldest online log sequence 27
    Next log sequence to archive 29
    Current log sequence 29
    Output from v$archive_dest_status:
    SQL> select dest_id,dest_name,status,error,type,database_mode from v$archive_dest_status;
    DEST_ID DEST_NAME STATUS ERROR TYPE DATABASE_MODE
    1 LOG_ARCHIV VALID LOCAL OPEN
    E_DEST_1
    2 LOG_ARCHIV BAD PARAM ORA-16053: LOCAL OPEN
    E_DEST_2 DB_UNIQUE_
    NAME is
    not in the
    Data Guard
    Configurat
    ion
    Please help me due to this problem i am not able to start standby database.Thanks in advance.
    Lake Worth, FL
    Talking
    Oracle Error :: ORA-16053
    DB_UNIQUE_NAME string is not in the Data Guard Configuration
    Cause
    The specified DB_UNIQUE_NAME is not in the Data Guard Configuration.
    Action
    If the DG_CONFIG attribute of the LOG_ARCHIVE_CONFIG parameter is enabled, you must specify a valid DB_UNIQUE_NAME. The list of valid DB_UNIQUE_NAMEs can be seen with the V$DATAGUARD_CONFIG view. This problem can also occur when specifying a non-standby destination with an DB_UNIQUE_NAME attribute that does not match the DB_UNIQUE_NAME initialization parameter for the current instance.
