Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
  1. #11
    yeah you posted that already
  2. #12
    May 2008
    I am new to AIX...
    I don't no how to Enable SSH in AIX
    Plz. send me the solution.
  3. #13
    May 2008
    Error OUI-25031
    doing RAC installation again got the error while a screen called
    Configuration assistants
    Oracle Notification server configuration assitant Succeeded Recommended.
    Oracle Private Interconnect Configuration assistant Succeeded Recommended.
    Oracle Cluster Verficiation Utility Failed Recommended
    With Error OUI-25031
    any one help out this problem
  4. #14
    May 2008
    Exclamation RAC, Oracle Cluster Verficiation Utility Failed @ cluster installation
    Dear Friends,
    Plz. help me out.
    Again I got the error while cluster installation, a screen called
    but there is no file ...
    /opt/crs/oracle/cfgtoollogs/configtoolfailedcommands in the nodes.
    & we verified the below commands with success results.
    cd /opt/crs/oracle/bin
    $./olsnodes -n
    it gave output
    rac1
    rac2
    Should I continue with this Cluster verification utility fail or should we wait.
    Muz
  5. #15
    its about time you opened an SR or found a dba as people on a forum cant help you
  6. #16
    May 2008
    Exclamation
    Already I have created SR, till now, i did'nt get any response overthere.
    please help me anyone.
    Thanx in advance,
    Muz
  7. #17
    Quote Originally Posted by muzammil.dba
    Thanx in advance,
    Muz
    At what severity level did you open your SR?
    Is it critical? call Oracle Support and ask them to escalate your SR to sev=1
    Also ask them to assign the SR to an engineer in your time zone.
  8. #18
    Lake Worth, FL
    Cool
    I am new to AIX...
    You enable ssh in AIX the same way as you do for any Unix.
    This is not valid: chmod 777 .ssh the permissions should be mode 700.
    Also the ~/.ssh/authorized_keys on the each site should be mode 600.
  9. #19
    Nov 2006
    Oracle RAC, problem
    Follow the steps in the attachment for your ssh configuration on AIX...
    divroro12
  10. #20
    May 2008
    Exclamation
    Hey All,
    Now ssh configured on AIX 5.3, but I face some other issue, when I am trying connect from Node1 to Node2 or Node2 to Node1 with the help of ssh, some time it will connect with in 1 second, & some time it will take more time(10-15 mints) to connect both the nodes & after couple of mininutes I got this error.
    $ ssh: connect to host rac1 port 22: Connection timed out
    plz. send me the solution.
    Muz
