Results 1 to 7 of 7
Thread: expdp
    May 2004
    NJ
    expdp
    When backing up database through expdp, would it also backup unused blocks? Or it only backed up the used ones?
    Claire
    expdp isnt a backup tool - it takes a logical copy of the data in the database and doesnt touch block level
    May 2004
    NJ
    So how to estimate the size of expdp dump file?
    Jun 2008
    There is no certain was to eastimate your size of the dump size to be .
    It's completly depends upon the size of the segments excluding the frgmented blocks. Some of the case it may increase the size as same as the source segment.
    So it is better to estimate as same size as the source segment.
    Lake Worth, FL
    Talking Estimate_only
    With datapump you can use the ESTIMATE_ONLY option which instructs Export to estimate the space that a job would consume, without actually performing the export operation.
    May 2004
    NJ
    Wow...this is great. Thank you so much......
    May 2004
    NJ
    I tried it and worked like champ!
