    Jan 2006
    Dynamic SQL within PL/SQL procedure and ORA-00905
    I tried to use dynamic SQL within a PL/SQL procedure to re-create materialized view. Because the SQL statement for the creation is long, I store these mv name, tablespace, refresh method, refresh key and SQL select statement in a local table called xxx_mv_information. Then I create procedure with dynamic SQL in. The procudure was compiled successfully. When I run the procedure, it always give me ORA-00905 missing key word error. I have carefully check the syntax and can not find the problems. Please help me to figure out where the problem is. Thanks a lot in advance. Here is the procedure I created.
    CREATE OR REPLACE PROCEDURE sp_recreat_mvs
    IS
    v_schema user_mviews.owner%type;
    v_sql_string varchar2(1000);
    v_sql_stmt varchar2(2000);
    SELECT DISTINCT OWNER
    INTO v_schema
    FROM USER_MVIEWS;
    SELECT TABSPACE||' '||REF_METHOD||' '||REF_KEY||' '||SQL_STRING
    INTO v_sql_string
    FROM XXX_MV_INFORMATION
    ORDER BY MV_NUM;
    FOR x IN (SELECT MV_NAME FROM XXX_MV_INFORMATION ORDER BY MV_NUM)
    LOOP
    v_sql_stmt := 'CREATE MATERIALIZED VIEW ' ||v_schema||'.'||x.mv_name||v_sql_string;
    EXECUTE IMMEDIATE v_sql_stmt;
    END LOOP;
    COMMIT;
    You have to double-check your dynamic sql syntax.
    Print out your v_sql_stmt command line before the EXECUTE IMMEDIATE statement, for sure you are going to see that you need a blank space before v_sql_string and who knows what else might be wrong.
    Jan 2006
    PAVB:
    You are right. The syntax is very important in this regard. I missed a space again and it works after adding space. But I have another piece of code here. I know is the space problem to cause the ORA-00905 missing keyword error. But I tried many ways and can not figure out where the space is missing or whatelse. Please comment on it. Thanks a lot.
    v_sql_stmt := 'CREATE MATERIALIZED VIEW '||v_schema||'.'||mv_record.mv_name|| mv_record.tabspace|| mv_record.ref_method|| mv_record.ref_key|| mv_record.sql_string;
    Ok... I'll teach you how to fish otherwise you are going to keep asking for a fish a couple of times a day.
    First thing to do is to convert your code below...
    ...into something like this:
    select  'CREATE MATERIALIZED VIEW '||'v_schema'||'.'||'mv_record.mv_name'||'mv_record.tabspace'||'mv_record.ref_method'||'mv_record.ref_key'||'mv_record.sql_string'
    from    dual;
    Please execute it and tell me if what it returns looks like the right syntax for the Create Materialized View command.
    Jan 2006
    Talking
    PVAB:
    Thanks for your teaching.
    Actually, I used dbms_output.put_line(v_sql_stmt) in SQL plus to find problem.
    Then I add space in string. Then it works. Thanks for your help.
    Nicely done. Way to go.
