Problem with freespace Ora-11g
Hi, i've a problem with the oracle partition, i've only 3MB of free space(on a partition of 6GB) but i've very little database with 16 table... its size is 250Mb maybe are there obsolete file that i can delete?
i'm using oracle 11g under solaris
I've seen in the directory app/bin file such as: emagtm0,dgmgrO ...
Files that end with 0 or O
what are these files? a backup copy of emagtm and dgmgr?
can i delete them?
On this partition there is only the oracle installation...
This is a print of df -k /app/oracle
File system kbyte used free capacity Actived on
/dev/dsk/c0t0d0s7 6050742 5986834 3401 100% /export/home
As you can see all the space has taken by oracle application directory.
you need to find the big files that you dont need and remove them - only you know.
And your database will be more than 250Mb
in this partition there is only the oracle installation, the OS is in another partition.
These are file more than 100 MB
What's the first ?ASMQueries.jar?
-bash-3.00$ find . -size +10024
./app/oracle/product/11.1.0/db_1/inventory/Queries21/ASMQueries/11.1.0.6.0/ASMQueries.jar
./app/oracle/product/11.1.0/db_1/apex/builder/de/f4000_de.sql
./app/oracle/product/11.1.0/db_1/apex/builder/de/f4500_de.sql
./app/oracle/product/11.1.0/db_1/apex/builder/es/f4000_es.sql
./app/oracle/product/11.1.0/db_1/apex/builder/es/f4500_es.sql
./app/oracle/product/11.1.0/db_1/apex/builder/fr/f4000_fr.sql
./app/oracle/product/11.1.0/db_1/apex/builder/fr/f4500_fr.sql
./app/oracle/product/11.1.0/db_1/apex/builder/it/f4000_it.sql
./app/oracle/product/11.1.0/db_1/apex/builder/it/f4500_it.sql
./app/oracle/product/11.1.0/db_1/apex/builder/ja/f4000_ja.sql
./app/oracle/product/11.1.0/db_1/apex/builder/ja/f4500_ja.sql
./app/oracle/product/11.1.0/db_1/apex/builder/ko/f4000_ko.sql
./app/oracle/product/11.1.0/db_1/apex/builder/ko/f4500_ko.sql
./app/oracle/product/11.1.0/db_1/apex/builder/pt-br/f4000_pt-br.sql
./app/oracle/product/11.1.0/db_1/apex/builder/pt-br/f4500_pt-br.sql
./app/oracle/product/11.1.0/db_1/apex/builder/zh-cn/f4000_zh-cn.sql
./app/oracle/product/11.1.0/db_1/apex/builder/zh-cn/f4500_zh-cn.sql
./app/oracle/product/11.1.0/db_1/apex/builder/zh-tw/f4000_zh-tw.sql
./app/oracle/product/11.1.0/db_1/apex/builder/zh-tw/f4500_zh-tw.sql
./app/oracle/product/11.1.0/db_1/apex/builder/f4000.sql
./app/oracle/product/11.1.0/db_1/apex/builder/f4500.sql
./app/oracle/product/11.1.0/db_1/apex/utilities/fop/fop.war
./app/oracle/product/11.1.0/db_1/assistants/dbca/templates/Seed_Database.dfb
./app/oracle/product/11.1.0/db_1/assistants/dbca/templates/Seed_Database.ctl
./app/oracle/product/11.1.0/db_1/assistants/dbca/templates/example01.dfb
./app/oracle/product/11.1.0/db_1/bin/amdu
./app/oracle/product/11.1.0/db_1/bin/oracle
./app/oracle/product/11.1.0/db_1/bin/wrap
./app/oracle/product/11.1.0/db_1/bin/oratclsh
./app/oracle/product/11.1.0/db_1/bin/plshprof
./app/oracle/product/11.1.0/db_1/bin/rman
./app/oracle/product/11.1.0/db_1/bin/proc
./app/oracle/product/11.1.0/db_1/bin/procob32
./app/oracle/product/11.1.0/db_1/bin/profor
./app/oracle/product/11.1.0/db_1/bin/rmanO
./app/oracle/product/11.1.0/db_1/bin/oratclsh0
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/dutch-expanded.stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/dutch-std.stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/dutch-std.tagged-stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/dutch-std.tagger-lexicon
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/german-nosplit.stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/german-nosplit.tagged-stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/hungarian-expanded.stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/japanese-expanded.index
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/japanese-std.index
./app/oracle/product/11.1.0/db_1/ctx/data/inxight/lang/korean-std.stemmer
./app/oracle/product/11.1.0/db_1/ctx/data/jalx/droldJA.dat
./app/oracle/product/11.1.0/db_1/ctx/lib/kpodardr.so
./app/oracle/product/11.1.0/db_1/instantclient32/libociei.so
./app/oracle/product/11.1.0/db_1/javavm/admin/classes.bin
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/fonts/ALBANWTJ.TTF
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/sparc/client/classes.jsa
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/sparc/client/libjvm.so
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/sparc/server/libjvm.so
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/sparcv9/server/libjvm.so
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/charsets.jar
./app/oracle/product/11.1.0/db_1/jdk/jre/lib/rt.jar
./app/oracle/product/11.1.0/db_1/jdk/lib/tools.jar
./app/oracle/product/11.1.0/db_1/jlib/oemlt.jar
./app/oracle/product/11.1.0/db_1/lib/libserver11.a
./app/oracle/product/11.1.0/db_1/lib/libinlxs11.so
./app/oracle/product/11.1.0/db_1/lib/libjavavm11.a
./app/oracle/product/11.1.0/db_1/lib/libordsdo11.a
./app/oracle/product/11.1.0/db_1/lib/libagtsh.so.1.0
./app/oracle/product/11.1.0/db_1/lib/libcore11.a
./app/oracle/product/11.1.0/db_1/lib/libclient11.a
./app/oracle/product/11.1.0/db_1/lib/libgeneric11.a
./app/oracle/product/11.1.0/db_1/lib/libplp11.a
./app/oracle/product/11.1.0/db_1/lib/libpls11.a
./app/oracle/product/11.1.0/db_1/lib/libxml11.a
./app/oracle/product/11.1.0/db_1/lib/libn11.a
./app/oracle/product/11.1.0/db_1/lib/libnnz11.so
./app/oracle/product/11.1.0/db_1/lib/libldapjclnt11.so
./app/oracle/product/11.1.0/db_1/lib/libnnz11.a
./app/oracle/product/11.1.0/db_1/lib/libclntsh.so.11.1
./app/oracle/product/11.1.0/db_1/lib/liborasdkbase.so.11.1
./app/oracle/product/11.1.0/db_1/lib/liborasdk.so.11.1
./app/oracle/product/11.1.0/db_1/lib32/libnnz11.a
./app/oracle/product/11.1.0/db_1/lib32/libnnz11.so
./app/oracle/product/11.1.0/db_1/lib32/libn11.a
./app/oracle/product/11.1.0/db_1/lib32/libclient11.a
./app/oracle/product/11.1.0/db_1/lib32/libgeneric11.a
./app/oracle/product/11.1.0/db_1/lib32/libpls11.a
./app/oracle/product/11.1.0/db_1/lib32/libplp11.a
./app/oracle/product/11.1.0/db_1/lib32/libxml11.a
./app/oracle/product/11.1.0/db_1/lib32/liborasdk.so.11.1
./app/oracle/product/11.1.0/db_1/lib32/liborasdkbase.so.11.1
./app/oracle/product/11.1.0/db_1/lib32/libclntsh.so.11.1
./app/oracle/product/11.1.0/db_1/lib32/libagtsh.so.1.0
./app/oracle/product/11.1.0/db_1/md/admin/sdoepsgl.plb
./app/oracle/product/11.1.0/db_1/oc4j/j2ee/home/applications/ascontrol.ear
./app/oracle/product/11.1.0/db_1/oc4j/j2ee/home/lib/oc4j-internal.jar
./app/oracle/product/11.1.0/db_1/oc4j/j2ee/oc4j_applications/applications/WFMGRApp.ear
./app/oracle/product/11.1.0/db_1/oc4j/j2ee/oc4j_applications/applications/WFMGRApp/WFMGRWebApp.war
./app/oracle/product/11.1.0/db_1/oc4j/toplink/jlib/toplink.jar
./app/oracle/product/11.1.0/db_1/owb/bridges/lib/vek10.jar
./app/oracle/product/11.1.0/db_1/owb/external/oc4j_applications/applications/WFMGRApp.ear
./app/oracle/product/11.1.0/db_1/owb/home/applications/ascontrol.ear
./app/oracle/product/11.1.0/db_1/owb/j2ee/owbb.war
./app/oracle/product/11.1.0/db_1/owb/lib/ext/jdev.jar
./app/oracle/product/11.1.0/db_1/owb/lib/ext/oembase-10_1_0.jar
./app/oracle/product/11.1.0/db_1/owb/lib/ext/oemtools-10_1_0.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/helpdoc.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/rts.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/OMBPlusHelp.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/nlsrts.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/reposimpl.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/ui.jar
./app/oracle/product/11.1.0/db_1/owb/lib/int/helpdoc_it.jar
./app/oracle/product/11.1.0/db_1/perl/lib/5.8.3/sun4-solaris-thread-multi-64/CORE/libperl.a
./app/oracle/product/11.1.0/db_1/rdbms/lib/libdbtools11.a
./app/oracle/product/11.1.0/db_1/rdbms/lib32/libdbtools11.a
./app/oracle/product/11.1.0/db_1/sqldeveloper/jdev/extensions/oracle.javacore.jar
./app/oracle/product/11.1.0/db_1/sysman/install/ccr.zip
./app/oracle/product/11.1.0/db_1/sysman/jlib/emCORE.jar
./app/oracle/product/11.1.0/db_1/sysman/jlib/emcoreALL.jar
./app/oracle/product/11.1.0/db_1/sysman/jlib/emcore_emjsp.jar
./app/oracle/product/11.1.0/db_1/sysman/jlib/jviewsall.jar
./app/oracle/product/11.1.0/db_1/sysman/jlib/emDB.jar
./app/oracle/product/11.1.0/db_1/sysman/jlib/emdb_emjsp.jar
./app/oracle/product/11.1.0/db_1/sysman/prov/paf/pa.par
./app/oracle/product/11.1.0/db_1/sysman/prov/paf/patchAdvisor.par
./app/oracle/product/11.1.0/db_1/ccr/inventory/pending/engines.jar
./app/oracle/product/11.1.0/db_1/EMStagePatches_oracledb/10/3F849311CCCF04CBE0440003BA03CFE3
./app/oracle/product/11.1.0/db_1/EMStagePatches_oracledb/6/3F849311CCCB04CBE0440003BA03CFE3
./app/oracle/product/11.1.0/db_1/EMStagePatches_oracledb/36/3F9819FA457D0533E0440003BA03CFE3
./app/oracle/product/11.1.0/db_1/EMStagePatches_oracledb/8/3F9819FA45810533E0440003BA03CFE3
./app/oracle/diag/rdbms/oracledb/oracle/ir/offline_dictionary.ir
./app/oracle/oradata/oracledb/system01.dbf
./app/oracle/oradata/oracledb/sysaux01.dbf
./app/oracle/oradata/oracledb/undotbs01.dbf
./app/oracle/oradata/oracledb/users01.dbf
./app/oracle/oradata/oracledb/control01.ctl
./app/oracle/oradata/oracledb/control02.ctl
./app/oracle/oradata/oracledb/control03.ctl
./app/oracle/oradata/oracledb/redo01.log
./app/oracle/oradata/oracledb/redo02.log
./app/oracle/oradata/oracledb/redo03.log
./app/oracle/oradata/oracledb/temp01.dbf
you have a database and all its datafiles in there, what do you expect?
yes but my database is very little only 16 tables...
isn't there nothing to do?
Add more space to the partition or mountpoint.
Did the person who installed oracel software read about the minimum hard disk space requirements for installing oracle11g ?
Hrishy
doesnt matter how many tables you have the DATABASE has a minimum space requirement.
Either give it more disk or move things about.
You need a dba to help you
these datafiles, indexes and system datafiles are important for your database, so if you delete them, it will cause an error......
isn't there a log file that i can delete? also 1 mb for me is very important
you tell us, are there any log files? did you look for them?
