ORA-00119: invalid specification for system parameter LOCAL_LISTENER
Thread: ORA-00119: invalid specification for system parameter LOCAL_LISTENER
    Dec 2007
    I am getting errors while starting up my database using command 'STARTUP'
    ORA-00132: syntax error or unresolved network name 'LISTENER_ORCL2'
    Please have a look on sqlnet.ora , tnsnames.ora, listener.ora
    sqlnet.ora
    # sqlnet.ora Network Configuration File: c:\oracle\product\10.2.0\db_2\network\admin\sqlnet.ora
    # Generated by Oracle configuration tools.
    # This file is actually generated by netca. But if customers choose to
    # install "Software Only", this file wont exist and without the native
    # authentication, they will not be able to connect to the database on NT.
    SQLNET.AUTHENTICATION_SERVICES= (NONE)
    #NAMES.DIRECTORY_PATH= (TNSNAMES, EZCONNECT)
    NAMES.DEFAULT_DOMAIN=snr.babu.com
    SQLNET.EXPIRE_TIME=10
    tnsnames.ora
    # tnsnames.ora Network Configuration File: c:\oracle\product\10.2.0\db_2\network\admin\tnsnames.ora
    LISTENER_ORCL2 =
    (ADDRESS = (PROTOCOL = TCP)(HOST = snr.babu.com)(PORT = 1522))
    ORCL2 =
    (DESCRIPTION =
    (CONNECT_DATA =
    (SERVER = DEDICATED)
    (SERVICE_NAME = orcl2)
    ORCL =
    (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST =snr.babu.com)(PORT = 1521))
    (CONNECT_DATA =
    (SERVICE_NAME = orcl)
    EXTPROC_CONNECTION_DATA =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC2))
    (CONNECT_DATA =
    (SID = PLSExtProc)
    (PRESENTATION = RO)
    listener.ora
    # listener.ora Network Configuration File: c:\oracle\product\10.2.0\db_2\network\admin\listener.ora
    SID_LIST_LISTENER =
    (SID_LIST =
    (SID_DESC =
    (SID_NAME = PLSExtProc)
    (ORACLE_HOME = c:\oracle\product\10.2.0\db_2)
    (PROGRAM = extproc)
    LISTENER =
    (DESCRIPTION_LIST =
    (DESCRIPTION =
    Thanks in Advance
    Apr 2006
    Try to modify your tnsnames.ora entry to the following:
    LISTENER_ORCL2 =
    (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = snr.babu.com)(PORT = 1522)))
    Nov 2006
    Sofia
    @ebrian what's the difference? That's already there
    @poster
    try to change LISTENER_ORCL2 to LISTENER_ORCL2.snr.babu.com in the tnsnames.ora and let su know if it works
    Apr 2006
    Quote Originally Posted by Bore
    It's like that game, "What's different between these two pictures?". Take a look again.
