batch file-startup skips
hi all,
In personal pc i have written a batch file as
sqlplus /nolog @c:\start
in start file i have written as
conn / as sysdba
startup pfile='e:\oracle\admin\prod\pfile\initprod.ora'
cl scr
prompt Welcome
if i run that batch file it connects to sqlplus waits for a while and the displays
Welcome message without starting up database,but if i run that start file it works properly.please guide..,
use something like this..
sqlplus /nolog
@c:\start
funky...
no.., it doesn't helps me.
thnx for ur reply
put some de-bugging messages...
funky...
You don't have to re-invent the wheel...
@echo off
rem -----------------------------------------------------------------------
rem Filename: DBStart.bat
rem Purpose: Start an Oracle database
rem Date: 05-Mar-2002
rem Author: Frank Naude, Oracle FAQ
rem -- Set Database SID --
set ORACLE_SID=sgnt
rem -- Create SQL Script to START the DB --
echo set echo on > %0.tmp
echo connect sys/orcl as sysdba; >> %0.tmp
echo startup force; >> %0.tmp
echo exit; >> %0.tmp
rem -- Do the Startup --
sqlplus /nolog @%0.tmp
rem -- Cleanup --
del %0.tmp
Pavb thanks for the help,
I have used Startup force command,now it works properly.
