10gR2 RAC nodeapps issue - ONS
Results 1 to 10 of 14
Thread: 10gR2 RAC nodeapps issue - ONS
    Jan 2004
    Bangalore, India
    Hello RAC Gurus,
    I have a two-node cluster on RHES 4, Oracle 10.2.0.3.
    Unfortunately, I did not install this particular system, but the maintenance has been assigned to me... :(
    Issue:
    ONS daemon is running on first node, but not on the second node.
    I tried starting ons using: $ORACLE_HOME/bin/onsctl start and onsctl ping command returns successfully mentioning ons is started.
    However, when I issue: srvctl status nodeapps -n , it still says ONS daemon is not running on node:
    Am I missing something here?
    Anyone, any ideas/thoughts?
    Thanks in advance!
    Suhas
    checked the logs?
    Jan 2004
    Bangalore, India
    which logs?
    $ORACE_HOME/opmn/logs/ons.log ?
    $ORA_CRS_HOME/log/$HOSTNAME/racg
    Jan 2004
    Bangalore, India
    Hello Pando,
    Here's a relevant excerpt from the ora..ons.log:
    2007-07-22 02:31:21.114: [ RACG][2540684544] [17186][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: clsrcexecut: cmd = /opt/oracle/crs/bin/racgeut -e _USR_ORA_DEBUG=0 540 /opt/oracle/crs/bin/onsctl ping
    2007-07-22 02:31:21.114: [ RACG][2540684544] [17186][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: clsrcexecut: rc = 1, time = 0.200s
    2007-07-22 02:31:21.114: [ RACG][2540684544] [17186][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: end for resource = ora.evg60lx-sscout-ora-rac2.ons, action = start, status = 1, time = 1.340s
    2007-07-22 02:31:21.361: [ RACG][2540684544] [17341][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: onsctl: shutting down ons daemon ...
    libclntsh.so dlopen failed:
    libclntsh.so: cannot open shared object file: No such file or directory
    Unable to open libclntsh.so
    onsctl: shutdown of ons failed!
    2007-07-22 02:31:21.361: [ RACG][2540684544] [17341][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: clsrcexecut: env ORACLE_CONFIG_HOME=/opt/oracle/crs
    2007-07-22 02:31:21.362: [ RACG][2540684544] [17341][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: clsrcexecut: cmd = /opt/oracle/crs/bin/racgeut -e _USR_ORA_DEBUG=0 540 /opt/oracle/crs/bin/onsctl stop
    2007-07-22 02:31:21.362: [ RACG][2540684544] [17341][2540684544][ora.evg60lx-sscout-ora-rac2.ons]: clsrcexecut: rc = 3, time = 0.210s
    and that's the end; no log entries since 07/22
    Please advice.
    Suhas
    I am not sure but looks like you need to do
    What are the contents of
    $ORACLE_HOME/opmn/logs/ons.log file
    Check the file permissions on the node where it is working
    ls -ltr $ORACLE_HOME/opmn/lib/lib*.so
    You might have to do on the other node this
    $ORACLE_HOME/opmn/bin/opmnctl stopall
    chmod o+rx $ORACLE_HOME/opmn/lib/lib*.so
    $ORACLE_HOME/opmn/bin/opmnctl start
    Please be careful as i am just speculating about this here as i am not completely sure
    Hrishy
    Jan 2004
    Bangalore, India
    Hrishy,
    A: 07/08/29 16:39:30 [2] Connection 0,172.18.0.212,6202 message out of sync:
    This is repeated 3-4 times.
    A: there's only one file in this folder: ons.jar
    A: There's no such executable in this folder; only "ons"
    Let me know if you can think of anything.
    Thanks!
    Suhas
    What about on the node where this is working fine
    what does this return
    Hrishy
    Jan 2004
    Bangalore, India
    Hrishy,
    There's only the one jar file on both nodes.
    Suhas
    Do you see anywhere libclntsh.so in the following path
    $ORACLE_CONFIG_HOME
    find . -name "libclntsh.so" $ORACLE_CONFIG_HOME
    the onsctl utility should be there in
    I am extremly sorry that i asked you to search in Oracle home instead of CR home
    Hrishy
