Results 1 to 10 of 10
Thread: Enterprise Manager startup
    May 2006
    Maryland
    I have installed Oracle 10g Enterprise Manager on linux VMware. When I type in
    [ebethea@localhost bin]$./emctl start dbconsole;
    I got a Environment Variable ORACLE_SID not defined. So I exported my ORACLE_SID and tried it again and got this error messege:
    OC4J Configuration issue. /home/ebethea/OraHome_1/oc4j/j2ee/OC4J_DBConsole_localhost.localdomain_test not found.
    Can anyone help me get past this point? I saw the other posting about this but it didn't help.
    Nov 2006
    Sofia
    emca -deconfig dbcosole db
    emca -config dbconsole db
    May 2006
    Maryland
    I am now getting this error message:
    bash: emca: command not found
    I switched to root and it still isn't working. Any help would be greatly appreciated.
    May 2006
    Maryland
    Sorry, I fixed the bash error message and I tried these commands:
    and they didn't work. I'm still getting error message:
    Nov 2006
    Sofia
    get back to Oracle.
    Never work as root
    May 2006
    Maryland
    Ok still having trouble. When I check my ORACLE_SID and ORACLE_HOME using this command:
    env |grep ORA
    I come up with 2 ORACLE_SID. Could this be the reason I'm getting the "OC4J" error? What do I do?
    you cant havr 2 ORACLE_SID's set, impossible
    May 2006
    Maryland
    EM startup
    I am still getting that OC4J Configuration issue. Metalink note 340820.1 says that The OC4J container for the dbconsole cannot initialize correctly because it is reading the ORACLE_SID from the enviromental variables and does not find the correct subdirectory.
    It tells me to Set ORACLE_SID ORACLE_HOME to the correct database and home directory. I did that and I still get the same error message.
    Do I need to redirect my OC4J to read the path of my ORACLE_SID? If so how do I do that?
    yes you still provide no proof
    Jun 2007
    İstanbul/Turkey
    when you are on oracle user,
    what happens when you try,
    cd $ORACLE_HOME/oc4j
    can you directly go in to the directory? if not,then it means you re setting it wrong.
    And also there are enviroment setting is emctl script too.Check them too,they must be true.
