Import problem KUP-11007 followed by ORA-26060
Thread: Import problem KUP-11007 followed by ORA-26060
    hi,
    While importing impdp, I am facing the following problem.
    KUP-11007 Conversion error loading table (SCHEMANAME.TABLENAME)
    ORA-26060 Can not convert type identifier for column (COLUMN NAME)
    This column name is referring to a type.
    > oerr ORA 26060
    26060, 0000, "Can not convert type identifier for column %s\n"
    //* Cause: The direct path API encountered a type identifier for a column that
    // can not be loaded because a mapping can not be found for the input
    // value.
    //* Action: Verify the input data.
