    Sep 2006
    drop tablespace problem
    I have a test schema (NCL) with two tablespaces WIZDATA containing tables of test schema and WIZINDX for indexes
    Now these tablespaces are no longer required
    SQL> drop tablespace wizdata including contents and datafiles;
    ORA-02449: unique/primary keys in table referenced by foreign keys
    SQL> drop tablespace wizdata including contents;
    SQL> drop tablespace wizindx including contents and datafiles;
    ORA-00604: error occurred at recursive SQL level 1
    ORA-02429: cannot drop index used for enforcement of unique/primary key
    SQL> drop user ncl cascade;
    User dropped.
    Tablespace dropped.
    Tablespace dropped.
    Now both of tablespaces have been droped after droping the schema NCL
    This is quite confusing for me
    Can anybody had encountered this problem?
    becuase you had data spanning tablespaces and droppping one of them would have broken your foreign key constraints.
    Did you not read the error, the part where it told you EXACTLY what the problem was
