Thread: auto logout interval on OEM
    Richardson, Texas, USA
    Oracle Enterprise Manager 10g has the auto logout feature that logs you out if you are inactive for a while. Is it possible to modify the interval somehow?
    Apr 2006
    You need to modify the value of oracle.sysman.eml.maxInactiveTime in the $IAS_HOME/sysman/config/emoms.properties file and then restart the Management Server.
    What is $IAS_HOME? I am not using the app server, just regular oracle server. I could not find a emoms.properties file. There is a emoms.properties.emca file but that does not have any maxInactiveTime property in it.
    Apr 2006
    For DB Control, you should set it in:
    $ORACLE_HOME/oc4j/j2ee/oc4j_applications/applications/em/em/WEB-INF/web.xml
    and set the following parameter to -1 (no limit):
    <session-config><session-timeout>-1</session-timeout></session-config>
    or if you like, you can specify a positive number to indicate the number of minutes before timeout.
