    Jan 2004
    Nottinghamshire, UK
    Angry ora-01031 insufficient privileges
    Got a newly upgraded db from 9i to 10g r2.
    Cannot use conn /as sysdba in sqlplus for the life of me. everything i read points to nt authentication but the user logged onto the server is in the ora_dba group.
    can connect another user as sysdba but prefer to use the above.
    any ideas??
    or is there a way to turn nt authentication off???
    cheers muchly sean
    Dec 2001
    Have u created the password file?
    that has got nothing to do with 'connect / as sysdba' password files arent used in that situation
    To the OP - whats in your sqlnet.ora file?
    Jan 2004
    Nottinghamshire, UK
    Sorted it, was a combination of the path enivro variable not being set correctly and also the sqlnet.ora file missing the nt authentication entry missing.
    cheers for your suggestions anyway.
