I had Developer 6.0.5 installed in one home with
Oracle 7.3.4...
Then I installed Forms 6i...
After that several product such as SQL Navigator during attempt
to connect to server write message "Entry point of xOCIReset procedure in ORA805.dll library not found".
I removed Forms6i, then Developer6.0.5 works properly?but several programms still write that message.
In the installation help of Forms6i is written that you shouldn't try to install the product in a home older (I guess) than 8i.
You have messed all of your Oracle 7 files.
You should try to uninstall all the Forms6i files and after that try to reinstall all Oracle7 products. I never did that but could work.
I wish you luck.
Valentin Mînzatu
