I recently purchased Solaris 8 and got an oracle 8.1.5 cd with it. When I try to start the instance, I get :
Ora-01078 failure in processing system parameters.
I have verified the /etc/system entries for oracle they are set as follows :
shmmax = 429496729500 ( I have tried 32000 upwards)
shmmin = 1
shmmni = 1000
shmseg = 100
semmni = 100
semmsl = 100
semmns = 1024
semopm = 100
My hardware is as follows :
Pentium Clarion
128 MB Ram
30GB storage
Operating System : Solaris 8 (intel)
Any Ideas?
Oracle 8.1.5 on Solaris 8 (intel)
There are many Notes on Metalink that refer to your problem. Below is just one:
Problem Description:
You have just installed Oracle 8.1.5. You are not using java and set the
JAVA_POOL_SIZE = 0 in the init.ora. On startup you get the following error:
ORA-01078: failure in processing initialization parameters
Cause: A failure occurred during processing of the initialization
parameters during system startup.
Action: Refer to the diagnostic information in the accompanying message
stack and take appropriate action.
Solution Description:
Set the JAVA_POOL_SIZE to a value greater than or equal to 1MB.
Explanation:
In 8.1.5 the minimum setting for the java_pool_size is 1MB due to a bug.
In 8.1.6, you can set the java_pool_size to 0, but 32768 will show up in a
SHOW PARAMETER command.
Thanks mhaller
The java_pool_size did the trick. Thanks Again
