amazing problem
Results 1 to 10 of 17
Thread: amazing problem
    Sep 2006
    amazing problem
    Hi Gurus,
    I am sgoogling and askTom for quite a while and I cannot find a good solution for my kind of problem.
    I have a table with a couple of rows, sometimes more sometimes less, the table will be created from a csv file using sqlloader.
    My problem is:
    PHP Code:
    from this table
    __________________________________________________________________________________________
    |       id    |    mon1        |    mon2    |    mon3    |    mon4    |    mon5    |
    |    1    |    1        |    2    |    5    |    2    |    1    |
    |    2    |    1        |    2    |    5    |    7    |    2    |
    all values should inserted into a new table: (these are routes from 1 point to another)
    Aid  |   mob1_id   |   mob2_id       |
    _____________________________|
    1    |      1       |       2              |
    ______________________________|
    1    |      2        |       5             |
    1    |       5       |       2             |
    1   |       2       |        1            |
    in words: just split each row in each colum and but it in the new table.
    I have already written a lot of code but nothing works..
    Maybe one of you had a similar problem.
    Help or a tipp would really be great...I am getting mad...
    THX a lot.
    Petra.
    Lake Worth, FL
    Cool
    Try this:
    PHP Code:
    Select idmon1mon2 From MyTable
    UNION
    Select id
    mon2mon3 From MyTable
    UNION
    Select id
    mon3mon4 From MyTable
    UNION
    Select id
    mon4mon5 From MyTable
    Order by 1
    ,2,3
    greenwich.ct.us
    That's amazing all right
    marist89@yahoo.com
    http://marist89.blogspot.com/
    Get Firefox!
    Colorado Springs
    Quote Originally Posted by LKBrwn_DBA
    Try this:
    PHP Code:
    UNION
    Select id
    UNION
    Select id
    UNION
    Select id
    Order by 1
    ,2,3
    UNION ALL, surely?
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Sep 2006
    Hello,
    thanks for your hint, but it's not working the way I need it.
    because the amount of values in the table1 is not always the same...sometimes there are 3, 5, or 7 values or more in a single row...
    Table1:
    1 mon1 mon2 mon5 mon2 mon1
    2 mon1 mon2 mon3 mon4 mon6 mon1 mon2 mon1
    3 mon1 mon5 mon1
    Table2: |
    1 mon1 mon2
    1 mon2 mon5
    1 mon5 mon2
    1 mon2 mon1
    2 mon1 mon2
    2 mon2 mon3
    2 mon3 mon4
    2 mon4 mon6
    2 mon6 mon2
    2 mon2 mon1
    then the union command does not work...
    any other suggestions...
    Thx...
    Petra.
    greenwich.ct.us
    no amount of programming will overcome a bad design.
    marist89@yahoo.com
    Get Firefox!
    Sep 2006
    Oh, thanks for that answer, but this is not based on a BAD Design.
    Colorado Springs
    Quote Originally Posted by petzi74
    why not?
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Sep 2006
    a row contains sometimes 4, sometimes 5, or 3, 6,7,8 values.
    As mentioned above this is not because of a bad design.
    A short explanation:
    these values are just objects of different routes - some routes have only 3 monizoring objects, another 4, or 5...etc.
    As soon as 1 route failed - every 10 minutes a token is send - the result is the route where the token has been failed.
    e.g. mon1 --> mon2 --> mon5 --> mon1
    Petra.
    Lake Worth, FL
    Cool
    Ok try this one (assuming there are no gaps (nulls) in the middle of route):
    PHP Code:
    Select IdMon1Mon2 From Mytable
    Union
    Select Id
    Mon2Mon3 From Mytable
     Where Mon3 Is Not Null
    Union
    Select Id
    Mon3Mon4 From Mytable
     Where Mon4 Is Not Null
    Union
    Select Id
    Mon4Mon5 From Mytable
     Where Mon5 Is Not Null
     Order By 1
    ,2,3
    PS: Union all will make no difference unless routes are duplicate.
