Results 1 to 8 of 8
Thread: URGENT - RMAN : ORA-19566: exceeded limit of 0 corrupt blocks for file XXX/XXX/syste
    Jul 2000
    Any suggestions?
    OS - Solaris
    DB - 10G
    Jul 2000
    My Rman Backup problem...
    ORA-19566: exceeded limit of 0 corrupt blocks for file /XXX/XXX/system01.dbf
    Need your help.
    you have corrupt blocks in your system tablespace. YOu probably want to get that sorted
    Apr 2006
    Since you don't have the MAXCORRUPT parameter set, you may want to run a BACKUP...VALIDATE and then review V$DATABASE_BLOCK_CORRUPTION for entries.
    These links may help:
    Detecting Physical Block Corruption With RMAN BACKUP... VALIDATE
    Handling Corrupt Datafile Blocks in RMAN Backup: MAXCORRUPT
    Performing Block Media Recovery with RMAN
    Jul 2000
    Any example would be very helpful..please
    an example of what? you need to work out what the exact problem is. Have you raised a TAR with oracle?
    Jul 2000
    Yes..TAR is open on that.
    I was looking for the exact syntax for SET MAXCORRUPT.
    set maxcorrupt for datafile 1 to .....
    Apr 2006
    Quote Originally Posted by dba_dada
    That's the correct syntax and you just specify a value where you have '...'
    You can also choose to do the following:
    RMAN> BACKUP VALIDATE DATAFILE 1;
    This will check that one file. You could also check all the files and archivelog files with:
    RMAN> BACKUP VALIDATE CHECK LOGICAL DATABASE ARCHIVELOG ALL;
    After the validate has finished, query V$DATABASE_BLOCK_CORRUPTION for records.
    However, as davey pointed out, this is your system tablespace's datafile, a TAR would be the best way to go.
