partition pruning with local index
Hi all,
System Info
Oracle version : 9i/10g
OS : All
My question is why "select count(*) from emptest where deptno=10;" is doing a full scan(of single partition).
1) It should do a partition pruning for deptno=10 (Which its doing)
2) Then it should go to the local index for that partiton and shd have done a fast full index scan to get the count(*) ,instead of doing a full table scan
My Reasoning:
- When you do a simple count(*) its doing a fast full index scan (all partition).
- when you do count(*) where deptno=10 it should have done a partiton pruning with deptno 10 and then it shd go to the linked local partition index to get it. i.e. it shd have done a fast full index scan (single partition-the local index partition which is linked to table partition with deptno 10).
ANY HELP PLEASE ???
Detail example below :
create table emptest(
EMPNO NUMBER not null,
ENAME VARCHAR2(50),
JOB CHAR(50),
MGR NUMBER,
HIREDATE DATE,
SAL NUMBER,
COMM NUMBER,
DEPTNO NUMBER
PARTITION BY list (deptno)
PARTITION p1 VALUES (10),
PARTITION p2 VALUES (20),
PARTITION p3 VALUES (30)
for i in 1..50000 loop
insert into emptest values(i,dbms_random.string(NULL,50),
'MGR',i+1,sysdate,10005,923,10) ;
if mod(i,1000)=0 then
commit;
end if;
end loop ;
end;
CREATE INDEX emptest_idx ON emptest(empno) LOCAL
(PARTITION ip1,
PARTITION ip2,
PARTITION ip3)
exec dbms_stats.gather_table_stats(USER,'EMPTEST',cascade=>true) ;
SQL> select count(*) from emptest ;
Execution Plan
0 SELECT STATEMENT Optimizer=CHOOSE (Cost=288 Card=1)
1 0 SORT (AGGREGATE)
2 1 PARTITION LIST (ALL) (Cost=288 Card=130000)
3 2 INDEX (FAST FULL SCAN) OF 'EMPTEST_IDX' (INDEX) (Cost=
288 Card=130000)
SQL> select count(*) from emptest where deptno=10;
Execution Plan
0 SELECT STATEMENT Optimizer=CHOOSE (Cost=2519 Card=1 Bytes=3)
2 1 PARTITION LIST (SINGLE) (Cost=2519 Card=130000 Bytes=390
000)
3 2 TABLE ACCESS (FULL) OF 'EMPTEST' (TABLE) (Cost=2519 Ca
rd=130000 Bytes=390000)
Manoranjan
Reason: Add Oracle Version
9i/10g
I have tested in both 9i rel2 and 10g rel1
Cheers
manoranjan
I would be interested in seeing the autotrace for both the statements.
Hrishy
The o/p already given to you are from
"set autotrace traceonly explain" only. In case you need any additional dat a please let me know
Thank You
Well the answer is simple both the queries are different.
I see that you have not created a index on deptno :-)
The query that is equivalent of
is
select count(*) from emptest partition(p1);
(dont look at the result i am saying optimizer wise they are equivalent now thats a term i made up)
I hope it answers your question
Hrishy
Hrishy Thanks for your reply. I got my answer from the following link
http://asktom.oracle.com/pls/ask/f?p...:1493222538541
.... Actually for non-prefixed index Oracle CBO is not geared up to handle this special and rare case
Cheers
Yeah not only oracle i dont think so any database can do what you are asking for.
Hrishy
