All,
I'm not having any luck searching for this question. Is there a way to find the maximum length of a variable in PL/SQL (ORA 9i).
For instance:
sample VARCHAR2(75);
I would like to return the value 75.
I thought perhaps this would work, but no luck.
LENGTH(sample%TYPE);
and LENGTH(sample) only returns the length of the string itself, not what the maximum could be. and MAXLENGTH doesn't seem to exist.
Thanks in advance.
--james
