issue with encrypt and decrypt
Thread: issue with encrypt and decrypt
    Mar 2004
    IA USA
    DBAs,
    We faced an issue with the encrypt and deencrypt with the obfuscate package.
    The situation is like this:
    prod database is 9.2.0.1, the dev is 9.2.0.6
    both of them are al32utf8.
    the nls_lang in both servers are set to al32utf8.
    we took a export from the prod and import into the dev.
    there are some columns like ssn and credit card number in one table
    cannot be deencrypted correctly in the dev. but they function very well in prod. we got the errors:
    ORA-28232: invalid input length for obfuscation toolkit
    BTW,most of rows can be deencrpted correctly.
    Only a small portion of rows cannot.
    for example;
    in dev;
    SQL> select 'ODDW',t.act_cd, dump(t.act_cd) from exam_person t where t.exam_person_id = 17973529;
    o[~Oj4 Li
    Typ=1 Len=15: 10,11,111,91,126,79,30,178,106,52,0,76,137,203,105
    in prod;
    o[~Oj4 Li
    Typ=1 Len=16: 10,11,111,91,126,79,30,178,106,52,0,76,137,203,105,240
    it looks like in the dev, the last 240 got cut off.
    We checked the export and import, The logs show they are done
    in al32utf8 character set.
    Any idea about this?
    Mar 2004
    IA USA
    FYT;
    the dmp file's head:
    $ cat erst_data_Jan23a2006 | od -x | head
    0000000 3000 2e00 0000 0000 0000 0000 0000 0000
    0000020 0007 2e2e 0000 0000 0000 0000 0000 0000
    0000040 3002 6578 706f 7274 5f73 746f 7265 5f64
    0000060
    how to interpret from this to know the exact character set fro this dmp file?
    Mar 2004
    IA USA
    Anyone can help with this? Thanks.
    Isn't it a good idea to have same Oracle release of dev and prod particularly when you try to implement some complex algorithm?
    Downgrade your dev env to 9.2.0.1
    OR
    Upgrade your prod to 9.2.0.6
    Tamil
