oracle 6i..set_block_property
i've tried to display a few records for a particular emp_id.if i wanted to display the records in la_date desc what should i write.
SET_BLOCK_PROPERTY
('leave_appl',DEFAULT_WHERE,'emp_id='||:PARAMETER.teka);
is there ordery by clause in set_block_property??
set_block_property
('leave_appl',DEFAULT_order_by,'la_date='||desc);
set_block_property
('leave_appl',order_by,column);
