    Sep 2005
    Guid Oracle datatype
    Dear All
    i have an insert query with ID column as PK as guid. the ID is NVARCHAR(40) - and i want to insert it to DB. i get all the time the folowing error
    "could not insert......within the expected range....."
    what is the problem?? the guid has the folowing format
    "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX")
    Feb 2005
    GUID is a sixteen byte RAW not a NVARCHAR
    http://download-west.oracle.com/docs...htm#sthref1826
    Where are you getting this "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX" from ?
