Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: SQL*PLUS Copy Command Limitation?
  1. #11
    Dec 2005
    Quote Originally Posted by robertbalmer
    what about environment settings
    sql>set array 1000
    sql>
    sql>set long 2000
    SQL> copy from user/user@1234 to user/user@4321 create test1 using select
    * from t1
    Array fetch/bind size is 1000. (arraysize is 1000)
    Will commit when done. (copycommit is 0)
    Maximum long size is 2000. (long is 2000)
    robert, i tried your suggestion still giving the same fetch out of sequence error.
    Does anyone tried to execute a copy command from ORA8.0 to ORA9i? Maybe this thing dont work at all.
  2. #12
    Didnt you answer slimdave that you were using 9i client to 9i database? Why you say you are using Oracle 8 now...?!
  3. #13
    The problem is most of us do not use Oracle 8.
    We have migrated to 8i / 9i / 10g....
    Hence, we do not have working env to test your case.
    Better, you should contact Oracle Support.
    Tamil
  4. #14
    Saskatoon, SK, Canada
    Given the issues, the solution is to use DBLINKs than COPY i.m.h.o.
    The problem exists all the way from 8.1.6. Looks like it is yet to be addressed by Oracle. I don't have the setup here, to do the test.
    Thanx,
  5. #15
    Quote Originally Posted by Bong
    Will having a long column give this error?
    No, it shouldn't (unless it is a bug).
  6. #16
    Dec 2005
    [QUOTE=sambavan]Given the issues, the solution is to use DBLINKs than COPY i.m.h.o.
    I agree with you. But DBLINK is actually the reason why I wanted to use COPY command because I can not DBLINK Orac8 and Ora9i.
    Any work around?
  7. #17
    why cant you dblink?
  8. #18
    Dec 2005
    Quote Originally Posted by davey23uk
    The DBLink from Oracle 8.0 to Oracle 9i is not working. Only from Oracle 8i to Oracle 9i is possible.
