How to check if a string contains only number and alphabetic characters?
Thread: How to check if a string contains only number and alphabetic characters?
    Hi, guys,
    I try to write a stored procedure to check if a string column contains specifial characters, I loop through each row of the table, then loop through each letter of the string, then do the following compare:
    IF
    (ascii(SUBSTR(string1, i, 1)) <= 47)
    OR
    (ascii(SUBSTR(string1, i, 1)) >= 58 AND ascii(SUBSTR(string1, i, 1)) <= 64)
    OR
    (ascii(SUBSTR(string1, i, 1)) >= 91 AND ascii(SUBSTR(string1, i, 1)) <= 96)
    OR
    (ascii(SUBSTR(string1, i, 1)) >= 123 AND ascii(SUBSTR(string1, i, 1)) <= 127)
    THEN
    it is a string contains special characters
    END IF
    But the performance is very bad because this table is huge, is there another way to do this?
    Have you narrowed down the list of special characters ?
    if yes then you can do a couple of things
    1)Upgrade to 10g and use its regex feautures
    2)Write a Java or a C regex function and call that from
    within sql
    Hrishy
    IF TRANSLATE (UPPER(l_string),
                  '#0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ',
                  '#') IS NOT NULL
    THEN
    END IF
