    Aug 2005
    Pro-C problem on Solaris
    In pro-c when one sql statement fails, then all subsequent sql statments fail. sqlca contains error message from the previous sql execution status.
    Suppose if "select emp_name from emp where emp_id = 100" no_data_found exception then all the sql operations fail (even the simple select statements like "select sequence.nextval from dual" would also fail. Can someone please help me.....
    nagraz
    Aug 2005
    sqlca is not getting populated when there is no sql statement is executed between beginning and end of transaction. What should I do to initialize the sqlca state in the pro-c code.
    Thanks in advance
    Aug 2005
    how to initialize sqlca struct before execution each sql statement
    Hi All,
    I hate to do this (posting again to be on top of the list). I thought I would re-phrase my question.
    After investigations, I found out that sqlca.sqlcode remains unchanged .
    Please have a look following steps.
    Steps :-
    1) Execute Sql - select emp_name from emp where emp_id = 100.
    Status :
    sqlca.sqlcode is set to 142343
    sqlca.sqlerrmc is set to :no_data_found.
    2) Execute sql - select sequence.nextval from dual
    Status :
    Result : correct value is selected but the sqlca.sqlcode is not changed.
    How can I initialize sqlca struct before execution of sqlca struct.
    I am depending on the
    It would be better to provide more information in the same thread than to create a new thread!
