Unexpected results using rownum
I'm trying to return just 100 rows from a table with the following code......
select membership_number, min(response_date)
from question_response_001
where response_date
between to_date('01/04/2004','dd/mm/yyyy') and
to_date('30/06/2004','dd/mm/yyyy')
and rownum < 101
group by membership_number
but I keep getting different result sets returned, i.e., 100 rows, 97 rows, 86 rows.
Is the 'group by' somehow affecting this??
The query is effectively finding the first 100 rows that match the criteria, then, from that resultset, doing the GROUP BY and MIN.
I would expect that if you ran that exact query over and over, it would return the same results each time (at least today, tomorrow may be different), however I would not necessarily expect 100 rows returned, If you change the date range, I would not be surprised to see a different number of rows returned every time.
HTH
John
you need to order by and then reduce by rownum. for example
select * from
(Select membership_number, min(response_date) resp_date
where response_date
order by resp_date desc
where rownum < 101
Reason: code formatting
Thanks for the advice,
The fundamental issue was that membership_number was not unique (not primary key). So the query returns 100 rows, some with the same membership_number. The 'group by' will then reduce the number of rows where a duplicate membership_number is found.
