Problem in Dynamic Sql
Thread: Problem in Dynamic Sql
    We have a function "test_dyanamic_before" in which we are dynamically calling another function "TEST_CHILD". I am pasting the sample codes but while running the test_dyanamic_before the flow always goes inside exception (see DBMS_OUTPUT.PUT_LINE('INSIDE EXCEPTION') in test_dyanamic_before how can i avoid this and what are we doing wrong.
    Select test_dyanamic_before(‘test_child’) from dual ;
    Its giving a error
    ORA-20000: ORA-06502: PL/SQL: numeric or value error: character string buffer too small ERRRRRRRRRRRROOOORRRRR ... Line: 29
    The samples are as follows
    TEST_CHILD
    CREATE OR REPLACE FUNCTION test_child(var_1 VARCHAR2,var_2 OUT VARCHAR2 )
    RETURN NUMBER AS
    var_3 VARCHAR2(10) := 'AAA';
    var_2 := var_3;
    --DBMS_OUTPUT.PUT_LINE('inside etst_child');
    RETURN length(var_2);
    --RETURN 0;
    TEST_DYNAMIC BEFORE
    CREATE OR REPLACE FUNCTION TEST_DYNAMIC_BEFORE(VAR_PROC VARCHAR2)
    RETURN NUMBER
    AS
    VAR_CMD VARCHAR2(2000);
    V_CURSOR_ID INTEGER;
    VAR_L_RETURN NUMBER;
    VAR_INPUT VARCHAR2(10) := 'TES';
    VAR_OUTPUT VARCHAR2(1000);
    DUMMY NUMBER;
    VAR_CMD := ' BEGIN '||
    ' :RET_CODE :=' || VAR_PROC || '(' ||
    ' :VAR_1,' || ':VAR_2' ||
    '); END;';
    -- FOR TESTING DYNAMIC SQL
    V_CURSOR_ID := DBMS_SQL.OPEN_CURSOR;
    DBMS_SQL.PARSE (V_CURSOR_ID,VAR_CMD,DBMS_SQL.V7 );
    DBMS_SQL.BIND_VARIABLE (V_CURSOR_ID,':RET_CODE',VAR_L_RETURN);
    DBMS_SQL.BIND_VARIABLE (V_CURSOR_ID,':VAR_1',VAR_INPUT);
    DBMS_SQL.BIND_VARIABLE(V_CURSOR_ID,':VAR_2',VAR_OUTPUT);
    dbms_output.put_line('HERE 1');
    DUMMY := DBMS_SQL.EXECUTE (V_CURSOR_ID);
    dbms_output.put_line('HERE 2');
    DBMS_SQL.VARIABLE_VALUE(V_CURSOR_ID,':VAR_2',VAR_OUTPUT);
    DBMS_SQL.CLOSE_CURSOR (V_CURSOR_ID);
    DBMS_OUTPUT.PUT_LINE('inside MAIN' || VAR_OUTPUT);
    --VAR_L_RETURN := TEST_CHILD(VAR_INPUT,VAR_OUTPUT);
    IF (VAR_L_RETURN != 0) THEN
    ORA_RAISERROR(29, 'EXECUTION OF PENALTY ROUTINE FAILED ...', 29);
    RETURN (VAR_L_RETURN);
    END IF;
    EXCEPTION
    WHEN OTHERS THEN
    IF DBMS_SQL.IS_OPEN(V_CURSOR_ID) THEN
    DBMS_SQL.CLOSE_CURSOR(V_CURSOR_ID);
    --RETURN 0;
    END IF;
    DBMS_OUTPUT.PUT_LINE('INSIDE EXCEPTION');
    --ORA_RAISERROR(SQLCODE, 'ERRRRRRRRRRRROOOORRRRR ...', 29);
    RETURN 80;
    PLz help
    Regds
    Aniruddha
    Aniruddha Gupta
    Jan 2004
    Pass an integer value to the DBMS_SQL.BIND_VARIABLE call for the OUT parameter size, e.g.
    DBMS_SQL.BIND_VARIABLE (v_cursor_id, ':VAR_2', var_output, 10);
    You do know all this would be trivial if you used EXECUTE IMMEDIATE don't you?
    Hi Padds,
    Thnnks for your reply and its working fine , I know about Execute Immediate but then while making a dynamic call to an finction (test_child) in our case it does not work.
    TEST_DYNAMIC_BEFORE using Execute Immediate
    CREATE OR REPLACE FUNCTION TEST_DYNAMIC_AFTER(VAR_PROC VARCHAR2)
    RETURN NUMBER
    AS
    VAR_INPUT VARCHAR2(10) ;
    DUMMY INTEGER;
    ' :ret_code :=' || VAR_PROC || '(' ||
    ' :var_1,' || ':var_2' ||
    '); END;';
    -- VAR_CMD := VAR_PROC || '(?,?)' ;
    dbms_output.put_line(VAR_CMD);
    DBMS_SQL.PARSE (V_CURSOR_ID,VAR_CMD,DBMS_SQL.NATIVE );
    DBMS_SQL.BIND_VARIABLE (V_CURSOR_ID,':ret_code',VAR_L_RETURN);
    DBMS_SQL.BIND_VARIABLE (V_CURSOR_ID,':var_1',VAR_INPUT);
    DBMS_SQL.BIND_VARIABLE (V_CURSOR_ID,':var_2',VAR_OUTPUT,10);
    dbms_output.put_line('HERE 1:' || TO_CHAR(V_CURSOR_ID));
    DBMS_SQL.VARIABLE_VALUE(V_CURSOR_ID,':var_2',VAR_OUTPUT);
    --DBMS_OUTPUT.PUT_LINE('inside MAIN' || VAR_CMD);
    EXECUTE IMMEDIATE VAR_CMD USING VAR_L_RETURN,VAR_INPUT, VAR_OUTPUT;
    END IF;
    EXCEPTION
    WHEN OTHERS THEN
    --RETURN 0;
    END IF;
    RETURN 80;
    Select test_dynamic_before('test_child') from dual;
    After making a call and passing the TEST_CHILD to this function this gives an error "ORA-20000: ORA-06536: IN bind variable bound to an OUT position ERRRRRRRRRRRROOOORRRRR ... Line: 29"
    Can u plz tell me how to use Execute Immediate in such cases.
    Aniruddha Gupta
    Jan 2003
    Hull, UK
    If you want to execute using Execute immediate the above statement, it can be done like this...
    Declare
             l_var varchar2(20);
    Execute Immediate 'select test_dynamic_before('test_child') from dual'   into l_var;
    dbms_output.put_line(l_var);
    Hope this is wht u want...
    Srini
    Jan 2004
    No offence but reading the manual might help. USING clause syntax allows you to specify IN (the default) / OUT / IN OUT for the parameters you are binding. For example...
    Oracle9i Enterprise Edition Release 9.2.0.6.0 - 64bit Production
    JServer Release 9.2.0.6.0 - Production
    SQL> CREATE OR REPLACE FUNCTION test_child (
      2     var_1         VARCHAR2,
      3     var_2   OUT   VARCHAR2)
      4     RETURN NUMBER
      5  AS
      6     var_3 VARCHAR2 (10) := 'AAA';
      7  BEGIN
      8     var_2 := var_3;
      9     RETURN LENGTH (var_2);
     10  END;
     11  /
    Function created.
    SQL> SET SERVEROUTPUT ON;
    SQL> DECLARE
      2    v_par_1 VARCHAR2 (10) := 'PAR1';
      3    v_par_2 VARCHAR2 (10) := 'PAR2';
      4    v_rtn NUMBER;
      5  BEGIN
      6    EXECUTE IMMEDIATE
      7      'BEGIN :1 := test_child (:2, :3); END;'
      8   USING OUT v_rtn, IN v_par_1, OUT v_par_2;
      9
     10    DBMS_OUTPUT.PUT_LINE ('v_par_1: ' || v_par_1);
     11    DBMS_OUTPUT.PUT_LINE ('v_par_2: ' || v_par_1);
     12    DBMS_OUTPUT.PUT_LINE ('v_rtn: ' || v_rtn);
     13  END;
     14  /
    v_par_1: PAR1
    v_par_2: PAR1
    v_rtn: 3
    SQL>
