Thread: Executing stored proc in Toad SQL Editor
    Jul 2005
    I have a stored procedure that returns a result set using a REF_CURSOR output parameter. How do I execute the stored procedure using TOAD SQL Editor instead of SQL Plus? I tried clicking on the Package and clicking the yellow thunderbolt and inserting the input parameters, but it is having viewing the result set - ref_cursor. Any ideas?
    Thanks in advance!
    Jan 2004
    (based on TOAD 8.5.3.2)
    When you are inserting parameters (the 'Set Parameters' dialogue) click the 'Options' button to access the 'Output Options' which lets you configure how ref cursors will be displayed. I pretty much just use the 'Load into grid from memory (strong and weak)' option.
    Jul 2005
    I'm running TOAD 8.0.0.47 and I don't see the 'Load into grid from memory (strong and weak)' option. When I click the print DBMS output or the Create and Write to table option I get an error.
    The procedure executes fine in SQL PLUS but I can't get it to execute using TOAD. I get the following error in the second declare statement below: Error: PLS-00320: the declaration of the type of this expression is incomplete or malformed
    DECLARE
    SAL_WKS UPK_GET_SALARY_AVAIL_WEEKS.ref_cursor;
    SAL_WKS_row SAL_WKS%ROWTYPE;
    Everything is spelled correctly and so I'm not sure why I would be getting that error.. The UPK_GET_SALARY_AVAIL_WEEKS create statement is:
    CREATE OR REPLACE PACKAGE UPK_GET_SALARY_AVAIL_WEEKS IS
    TYPE ref_cursor IS REF CURSOR;
    PROCEDURE USP_C_TMWKSL_GET_SAL_WEEKS_SEL ( I_EMP_NUM VARCHAR2,
    I_EMP_ROLE VARCHAR2, SAL_WKS OUT ref_cursor );
    I'm quite confused...
    Jan 2004
    I suppose downloading an upgrade is out of the question?
    Jul 2005
    Good question... probably is out of the question at the moment..
