listener problem
Hi everybody,
i am facing listener related problem,actually we were created database in laptop,this
is just for demo presentation means only one or two clients who access this database.Problem comes when laptop goes to different network mean different country that time ip become changed due to this listener not work properly i use host namimg but host name not works properlly pls suggest me what to do.
Originally Posted by davey23uk
run it on 127.0.0.1
I already use this Ip address but it not always works.Is there any other solution by using host name
Where are you using the IP 127.0.0.1 ? Actual ip of the machine or the ip address mentioned in the listener.ora ?
Amar
Personally, I'd try using IPC protocol in this case, but Howard Rogers disagrees with me. His solution is to install a "loopback adapter" - see the link in this: http://www.dizwell.com/html/dhcp.html
"The power of instruction is seldom of much efficacy except in those happy dispositions where it is almost superfluous" - Gibbon, quoted by R.P.Feynman
