Sql query
Results 1 to 10 of 13
Thread: Sql query
    Sep 2001
    UK
    Sql query
    I have an input string ('a','b','c')
    Is there any way i can get the follg o/p using SQL (8i or 91 or 10g) (No PL/SQL)
    'a'
    'b'
    'c'
    I need the result to be displayed as 3 records
    instead of 1 record
    The no of columns in string may vary
    Thnx in advance
    Jun 2005
    UK
    A strange requirement for no PL/SQL, but here's a SQL-only solution, though you will need a SQL collection type. What I've done is to determine the number of delimited elements in each string and then generate a row per element "on the fly". Using a combination of INSTR, SUBSTR and the element number, it is possible to parse out the individual values.
    Note that in the example, I've commented out a REGEXP_REPLACE function ( 10g ). Including this was bombing my session. YMMV.
    SQL> CREATE TABLE t
      2  ( str VARCHAR2(30) );
    Table created.
    SQL>
    SQL> INSERT INTO t VALUES ( 'X,Y,Z' );
    1 row created.
    SQL> INSERT INTO t VALUES ( 'XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG' );
    1 row created.
    SQL>
    SQL> CREATE TYPE number_ntt AS TABLE OF NUMBER;
      2  /
    Type created.
    SQL>
    SQL> WITH ilv AS
      2     (
      3      SELECT str || ',' AS str
      4      ,      LENGTH(
      5                TRANSLATE(
      6                   UPPER( str ), ',ABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890!', ',' ) ) + 1 AS no_of_elements
      7      --,      LENGTH( REGEXP_REPLACE( s, '[[:alnum:]]' ) ) + 1 AS no_of_elements
      8      FROM   t
      9     )
     10  SELECT RTRIM(str,',') AS original_string
     11  ,      SUBSTR( str, start_pos, (next_pos-start_pos) ) AS single_element
     12  ,      element_no
     13  FROM  (
     14         SELECT ilv.str
     15         ,      nt.column_value AS element_no
     16         ,      INSTR(
     17                   ilv.str,
     18                   ',',
     19                   DECODE( nt.column_value, 1, 0, 1 ),
     20                   DECODE( nt.column_value, 1, 1, nt.column_value-1 ) ) + 1 AS start_pos
     21         ,      INSTR(
     22                   ilv.str,
     23                   ',',
     24                   1,
     25                   DECODE( nt.column_value, 1, 1, nt.column_value ) ) AS next_pos
     26         FROM   ilv
     27         ,      TABLE(
     28                   CAST(
     29                      MULTISET(
     30                         SELECT ROWNUM FROM dual CONNECT BY ROWNUM < ilv.no_of_elements
     31                         ) AS number_ntt ) ) nt
     32        );
    ORIGINAL_STRING                 SINGLE_ELEMENT                  ELEMENT_NO
    X,Y,Z                           X                                        1
    X,Y,Z                           Y                                        2
    X,Y,Z                           Z                                        3
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  XXX                                      1
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  Y                                        2
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  ZZ                                       3
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  AAAAA                                    4
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  B                                        5
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  CCC                                      6
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  D                                        7
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  E                                        8
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  F                                        9
    XXX,Y,ZZ,AAAAA,B,CCC,D,E,F,GGG  GGG                                     10
    13 rows selected.
    Adrian
    Nov 2001
    The Netherlands
    If you have a table containing at least as many records as the input values, you can use the following query
    select substr(:x,begin,end-begin)
    from (select pos+1 begin,nvl(lead(pos) over (order by pos),length(:x)+1) end
         from (select instr(:x,',',1,rownum) pos
          from dba_objects)
       where rownum <= length(:x)-length(replace(:x,','))+1
    SQL> exec :x := 'a,b,c,d,e,f,g,h'
    PL/SQL-procedure is geslaagd.
    SQL> select substr(:x,begin,end-begin)
    2 from (select pos+1 begin,nvl(lead(pos) over (order by pos),length(:x)+1) end
    3 from (select instr(:x,',',1,rownum) pos
    4 from dba_objects)
    5 where rownum <= length(:x)-length(replace(:x,','))+1
    6 );
    SUBSTR(:X,BEGIN,END-BEGIN)
    a
    b
    c
    d
    e
    f
    g
    h
    8 rijen zijn geselecteerd.
    Arian
    Jun 2005
    UK
    Arian,
    I think the OP has a whole table full of these strings and as such, you need to consider a join.
    Adrian
    Nov 2001
    The Netherlands
    Adrian,
    I don't see why I need a join. I just need a table with sufficient rows. And in 9i and up, I could use dual with a connect by clause to generate sufficient rows.
    Arian
    Jun 2005
    UK
    If you look at my example, I have a table "T" with more than one string of different sizes, as specified by the OP. You need to consider how you would replace your :x bind variable with a SELECT from the table of strings. It's less simple when you need to extract the elements from more than one string.
    Adrian
    Nov 2001
    The Netherlands
    Ok. I didn't understand from the question that there is a table.
    Unfortunately, I can't run your query, since we're still on 8i. So I had to try something else.
     select str, substr(str,begin,end-begin) element
     from (select str,pos+1 begin,nvl(lead(pos) over (partition by tri order by pos),length(str)+1) end
     	   from (select a.str, instr(a.str,',',1,o.rn) pos, a.tri
     	   		 from (select t.str,length(t.str)-length(replace(t.str,','))+1 num_el,t.rowid tri
    			 	   from t
    			      ) a
     			 ,    (select rownum rn, object_id
    			       from dba_objects) o
    			 where o.rn<=a.num_el
    SQL>  CREATE TABLE t
    Tabel is aangemaakt.
    1 rij is aangemaakt.
    SQL>  select str, substr(str,begin,end-begin) element
      2   from (select str,pos+1 begin,nvl(lead(pos) over (partition by tri order by pos),length(str)+1)
     end
      3       from (select a.str, instr(a.str,',',1,o.rn) pos, a.tri
      4          from (select t.str,length(t.str)-length(replace(t.str,','))+1 num_el,t.rowid tri
      5          from t
      6           ) a
      7       ,    (select rownum rn, object_id
      8            from dba_objects) o
      9      where o.rn<=a.num_el
     10      )
     11        );
    STR                            ELEMENT
    X,Y,Z                          X
    X,Y,Z                          Y
    X,Y,Z                          Z
    STR                            ELEMENT
    13 rijen zijn geselecteerd.
    Arian
    Edit: I realized later, that I used dba_objects as a matter of habit. Replace that with all_objects. In your case all_objects, or a custom-made table with sufficient rows would suffice. From 9i on, dual with a connect by is a safe replacement.
    Nov 2001
    The Netherlands
    To Adrian: Wonder about 9i
    Hi Adrian,
    Hope you'll be able to follow up on this reply.
    I tested your script on my own server. And I received an ORA-3113.
    So I was wondering what versions you used to test your script. I tested on 8.1.7.4 and 9.2.0.5.
    If you managed to run it on <=9.2.0.5, I'd like to file a bug with Oracle Support.
    Arian
    P.S. Wonder when people get confused about our names?
    Jun 2005
    UK
    Arian,
    The query posted above was tested on 10.1.0.3 only, but it is all 9i syntax. I was getting the ORA-3113 when I included the REGEXP_REPLACE. But, I have an 8i version that I also wrote and forgot to post ( the OP asked for all versions ). You could perhaps test this:-
    SELECT RTRIM( str,',' ) AS original_string
    ,      element_no
    FROM  (
           SELECT ilv.str
           ,      INSTR(
                     ilv.str,
           ,      INSTR(
                     ilv.str,
                     1,
           FROM  (
                  ,      LENGTH(
                            TRANSLATE(
                               UPPER( str ),
                               ',ABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890', ',' ) ) + 1 AS no_of_elements
                  FROM   t
                 ) ilv
           ,      TABLE(
                     CAST(
                        MULTISET(
                           SELECT ROWNUM FROM all_objects WHERE ROWNUM <= ilv.no_of_elements
    Arian, I mean, Adrian...
    Jun 2005
    London, UK
    Just for fun, try this (requires 9i, tested in 9.2.0.1):
    SELECT str, EXTRACTVALUE(xt.column_value,'e') AS name
    FROM   t
         , TABLE(XMLSEQUENCE
           ( EXTRACT
             ( XMLTYPE('<coll><e>' ||
                       REPLACE(t.str,',','</e><e>') ||
                       '</e></coll>')
    	 , '/coll/e') )) xt;
