Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: SQL CASE statement with Multiple THEN's
  1. #11
    Dec 2001
    UK
    Hi.
    I see the same issue with the context approach:
    CREATE OR REPLACE CONTEXT app_ctx USING set_ctx;
    CREATE OR REPLACE PACKAGE set_ctx AS
    FUNCTION set_attr (p_attr1  IN  VARCHAR2,
                       p_attr2  IN  VARCHAR2)
      RETURN VARCHAR2;
    END set_ctx;
    CREATE OR REPLACE PACKAGE BODY set_ctx IS
      RETURN VARCHAR2 IS
      DBMS_SESSION.set_context('app_ctx', 'attr1', p_attr1);
      DBMS_SESSION.set_context('app_ctx', 'attr2', p_attr2);
      RETURN 'COMPLETE';
    END set_ctx;
    SHOW ERRORS
    SELECT SYS_CONTEXT( 'app_ctx', 'attr1' ) AS get_1
    ,      SYS_CONTEXT( 'app_ctx', 'attr2' ) AS get_2
    FROM  (SELECT CASE
                    WHEN 1 = 1 THEN
                      set_ctx.set_attr ('definitely', 'not')
                    END
           FROM   dual
           ORDER BY 1);
    GET_1
    GET_2
    1 row selected.
    SELECT CASE
                    WHEN 1 = 1 THEN
                    END
           FROM   dual
           ORDER BY 1;
    CASEWHEN1=1THENSET_CTX.SET_ATT
    COMPLETE
    1 row selected.
    FROM dual;
    GET_1
    GET_2
    definitely
    not
    1 row selected.
    Am I going mad?
    Cheers
    Tim...
    Tim...
    OCP DBA 7.3, 8, 8i, 9i, 10g, 11g
    OCA PL/SQL Developer
    Oracle ACE Director
    My website: oracle-base.com
    My blog: oracle-base.com/blog
  2. #12
    Jun 2005
    UK
    You're not going mad ( well almost, but not quite ). It's something to do with FAST DUAL, as mentioned on my previous post. If we use a pipelined function as a single row source instead, it works:-
    SQL> SELECT package_name.get_a,
      2         package_name.get_b
      3  FROM  ( SELECT (CASE
      4                   WHEN 1 = 1 THEN
      5                     package_name.set_a_b (1, 2)
      6                   END)
      7           FROM   TABLE( one_row )
      8           ORDER BY 1);
         GET_A      GET_B
             1          2
    Wonder what optimisation FAST DUAL has that makes it behave like this?
    Adrian
  3. #13
    Dec 2001
    UK
    Quote Originally Posted by billiauk
    Interesting this. Same is true on Windows. At first I thought it could be merging, but I see that Padders included an ORDER BY, presumably for this very reason ( i.e. force no merge ).
    The only difference in 10g with this that I can see is the FAST DUAL optimisation. I can't see anything else in trace. It could be a bug of course. It doesn't appear to be anything to do with the PLSQL_OPTIMIZE_LEVEL either - setting this to 0 made no difference.
    Sorry, didn't see this before posting the thing about the context suffering the same fate.
    Cheers
    Tim...
    Tim...
    Oracle ACE Director
  4. #14
    Jun 2005
    UK
    Actually, FAST DUAL might be a red herring. Forcing "normal" DUAL doesn't see to make a difference either.
      4                   WHEN 1 = 1 THEN
      6                   END)
      7          ,       dummy
      8           FROM   dual
      9           ORDER BY 1);
         GET_A      GET_B
    SQL>
    SQL>
    SQL> select * from table( dbms_xplan.display_cursor );
    PLAN_TABLE_OUTPUT
    SQL_ID  79rukd61zu5sr, child number 0
    SELECT package_name.get_a,        package_name.get_b FROM  ( SELECT
    (CASE                  WHEN 1 = 1 THEN
    package_name.set_a_b (1, 2)                  END)         ,       dummy
             FROM   dual          ORDER BY 1)
    Plan hash value: 2367845099
    | Id  | Operation          | Name | Rows  | Bytes | Cost (%CPU)| Time     |
    PLAN_TABLE_OUTPUT
    |   0 | SELECT STATEMENT   |      |       |       |     3 (100)|          |
    |   1 |  VIEW              |      |     1 |       |     3  (34)| 00:00:01 |
    |   2 |   TABLE ACCESS FULL| DUAL |     1 |     2 |     2   (0)| 00:00:01 |
    Adrian
  5. #15
    Jun 2005
    UK
    Right, this is my last post on this one. Including a column in the outer projection seems to help. Without it, there is no projection at all. I still think this is a bug as I can't see what difference this could make as the plans are the same.
    SQL> exec dbms_session.reset_package;
      2         package_name.get_b,
      3         some_col
      4  FROM  ( SELECT (CASE
      5                   WHEN 1 = 1 THEN
      6                     package_name.set_a_b (1, 2)
      7                   END) AS some_col
      8           FROM   dual
      9           ORDER BY 1);
         GET_A      GET_B SOME_COL
             1          2 COMPLETE
    I like the object type method best ;o)
    Adrian
