Results 1 to 10 of 14
    Jolo, Sulu
    sqlplus vs pl/sql
    Hi Friends,
    I have a partitioned table DEPARTURE_ALL partitioned by
    DEPARTURE_DATE and a global index on FULLNAME. The table have
    50 million rows.
    Then I created the following sqlplus code and
    run against it.
    select surname,firStname from departure_all
    where ((fullname like 'TOM%WELLING%') or (fullname like 'WELLING%TOM%'))
    and departure_date>'31-DEC-04' and rownum<2;
    The response time is fast for the above code. But when I translated it to pl/sql
    code which is the following:
    select surname,firstname into x_surname,x_firstname from departure_all
    where ((fullname like p_surname||'%'||p_firstname||'%') or
    (fullname like p_firstname||'%'||p_surname||'%'))
    It took very long time, and it is doing a full table scan.
    Is there something wrong with my program translation?
    I try removing the condition [departure_date>'31-DEC-04'] and
    the program works fine. What is wrong with this partitioned key pls?
    Thanks a lot
    Apr 2003
    Pass the command same as the sql command and try.
    Create two variables and generate the values there.
    V_1:=p_surname||'%'||p_firstname||'%';
    v_2:=p_firstname||'%'||p_surname||'%';
    Run the changed sql.
    where ((fullname like v_1) or
    (fullname like v_2))
    Jolo, Sulu
    Thanks dear,
    But it is still doing full table scan
    Im puzzled about the departure_date, why is it that when i remove it
    the response is fast(in pl/sql mode), But while on the sqlplus mode
    with or without the departure_date the performance is ok.
    look at nls settings, you should really use to_date in the query as well (as you were told last time).
    Why isnt there an index on that column?
    Jolo, Sulu
    Yes dear, i tried also ...
    where departure_date>to_date('31-DEC-2004','DD-MON-YYYY')
    and same poor performance i got.
    I did not create an index on the departure_date coz of its low
    cardinality and we only query by fullname. Its primary purpose
    is to group the departure table by year.
    What puzzled me is that does sqlplus and pl/sql have different
    costbased optimizer interpretation?
    I also observed that if i used the partition for searching
    with the global indexed FULLNAME it will not use the index too.
    example1: (this uses the global index FULLNAME)
    example2: (this does a full table scan)
    select surname,firStname from departure_all partition(depart2005)
    Apr 2003
    and trunc(departure_date+0) >'31-DEC-04' and rownum<2
    Flush your shared pool before this. I know this column is not having index. But just a try.
    Jolo, Sulu
    Wow!!! It worked!!!!!
    Thanks a lot dear engiri/davey mwuahhhh!
    Apr 2003
    May be genius dba's give explanation, which I dont know for
    this behaviour.
    But when same kind of situation when we faced, after long analysis,
    I found some of these kind of things worked.
    Jolo, Sulu
    Well i guess in the pl/sql env, the optimizer is prioritizing the partitioned key as against the global index key
    By the way would the logic be the same if i use
    trunc(departure_date) as against trunc(departure_date+0)? Why add 0
    But NOTE also that putting the TRUNC on date w/o the v_1 and
    v_2 variables does not work also. lol...nice u got that idea too
    thanks
    Dec 2002
    Bangalore ( India )
    this behaviour.
    In SQLPLUS he is using hard coded values and may be its going for index scans on fullname, but if u notice in PL/SQL block its a variable and oracle is not choosing for index scans but for partition full scans. when you put a trunc on that column you are actually forcing oracle to use index scans on the col Fullname..
    suggestion : Collect stats on columns full name and departure_date.. may be it will help.
    Abhay.
    funky...
