Thread: Problem with db link usage
    Feb 2005
    I have a PL/SQL code which will try to list a set of tables from the remote database & try displaying. When I ran the code, I am getting the error
    declare
    cursor table_list_c is
    (select table_owner||'.'||table_name tab_name from scr_process@scr_link
    MINUS
    select owner||'.'||table_name tab_name from dba_tables@scr_link
    table_name_v scr_process.table_name@scr_link%type;
    for table_name_v in table_list_c
    loop
    dbms_output.put_line(table_name_v.tab_name);
    end loop;
    end;
    declare
    ORA-04052: error occurred when looking up remote object
    SYS.X$KSPPI@SCR_LINK.US.ORACLE.COM
    ORA-00604: error occurred at recursive SQL level 1
    ORA-02068: following severe error from SCR_LINK
    ORA-03113: end-of-file on communication channel
    DB link(scr_link) is working properly & even the inner sql query when I run separately, it is working fine.
    Please suggest what is going wrong here? What can I do to make it to work?
    Thanks in advance
    greenwich.ct.us
    sounds like you had an ora-600 or ora-7445 on the remote host.
    Apr 2003
    where (owner||'.'||table_name ) not in(
    Try the above.
    Aug 2001
    chennai,bangalore
    A work around is create a synonym for the object using db link and try if it works.
    anandkl
    anandkl
