Sir,
As you know we were using TRUNC function in DATE datatype. But I want to use it with TIMESTAMP datatypes. For example:
select trunc(systimestamp,'hh24:mi:ss') from dual;
The main idea to get some part of given timestamp without using type conversions (i.e. TO_CHAR).
Note that this is useful when you want to ADD or Subtract the time side from timestamp with interval values and comparing them to another timestamps fields or values.
Sir,
When using EXTRACT you can just get one type at a time -in your example you got only the Hour side-. But I need get the time part (i.e. HH24:MI:SS) which is applicable on DATE datatype by using TRUNC.
Originally posted by Lowaiy ..... which is applicable on DATE datatype by using TRUNC.
No, it is not (as padders allready said). You can get time portion of the date unly by using TO_CHAR(), you can't get it with TRUNC(). And this behavior is the same for DATE and TIMESTAMP datatype (also, as padders allready told you).
Jurij Modic ASCII a stupid question, get a stupid ANSI
Sorry sir, you're right...
But I still expect function could do this without converting it to char datatype. It's important -as I said- when you want to add an interval value and Add/Subtract another time value and make some comparisons. Definitely you don't like something like this:
L_Delta_All:=To_Timestamp(to_char(F_TIME_IN_OUT+F_MARGIN_IN_OUT_AFTER,'hh24:mi:ss'),'hh24:mi:ss')-
To_Timestamp(to_char(F_TXN_IN_OUT,'hh24:mi:ss'),'hh24:mi:ss');
The previous statement is simple Add Time portion to Interval and subtracts the time portion from another field.
L_Delta_All:=(F_TIME_IN_OUT + F_MARGIN_IN_OUT_AFTER) - F_TXN_IN_OUT;
So there's anyway in order to make the previous statement in simplest way.
Personal Oracle Database 10g Release 10.1.0.2.0 - Production
With the Partitioning, OLAP and Data Mining options
SQL> SELECT current_timestamp - TRUNC (current_timestamp) time
2 FROM dual;
TIME
+000000000 14:53:04.941000
SQL>
So What... Oracle DB Bug...? Huh... Or new feature...
Oracle9i Enterprise Edition Release 9.2.0.1.0 - Production
With the Partitioning, OLAP and Oracle Data Mining options
JServer Release 9.2.0.1.0 - Production
2 FROM dual
3 /
ORA-00932: inconsistent datatypes: expected NUMBER got TIMESTAMP
