    Hi all,
    1. I have created a new controlfile using the create controlfile command.
    2. while opening the db , I got the following error.
    ORA-01113 File 1 needs media recovery
    ORA-01110 data fiel 1: 'e:\test\sys1test.ora'
    3. Tried, RECOVER DATABASE USING BACKUP CONTROLFILE;
    ORA-00289 suggestion: e:\archive\tests0000000055.arc
    But the suggested file is missing , what should i do?
    Thanks in advance
    Jee
    After creating a new control file you will need to recover the database by typing ( at the server manager ) nomount mode :
    Recover Database;
    Hisham Nagia
    IT Manager For Development
    Oracle Consultant - OCP
    you can use
    RECOVER DATABASE USING BACKUP CONTROLFILE UNTIL CANCEL;
    press RTN for each arch log
    enter "cancel" when the file missing.
    Mar 2000
    CA
    Apply all the archive logs as long as they are available. If you are still concerned about database loss, you may also want to give the present redo log also. Then enter cancel and open the database. It should work.
    Kishore Kumar
