Thread: Question on 'Group by' and 'Sum'
    London
    The following sql
    select fs.tablespace_name,
    (100*((df.bytes-sum(fs.bytes))/df.bytes)) "% Used"
    from sys.dba_data_files df, sys.dba_free_space fs
    where df.file_id(+) = fs.file_id
    group by fs.tablespace_name, df.bytes;
    gives me the output:
    TABLESPACE_NAME % Used
    BOSTOCK 68.798828
    BOSTOCK 36.044922
    BOSTOCK 95.453333
    RBS 10.6
    RBS 10.466667
    RBS 5.6111111
    SERVER_INFO 2.5
    STAGE 50.25
    but as you can see, it is giving me row per number of datafiles in each tablespace. It needs to be one row per tablespace (i.e. here I want the sum of Bostock and RBS instead of three row each)
    Is it possible to modify the Group by statement so they will add up? Or is there other ways to do that, like using Sum? (which I also have no clues!)
    Thanx in advance
    Fiona
    Smile
    Use this select instead:
    SELECT A.TABLESPACE_NAME TABLESPACE,
    ROUND(A.BYTES/1048576,1) MB_TOTAL,
    ROUND(NVL(B.BYTES/1048576, 0), 1) MB_USILISE,
    ROUND(((NVL(B.BYTES,0) * 100) / A.BYTES), 1) "UTILISATION(%)"
    FROM (select tablespace_name, sum(bytes) bytes
    from dba_data_files
    group by tablespace_name) A,
    sum(bytes) bytes
    from dba_extents
    group by tablespace_name) B
    WHERE A.TABLESPACE_NAME = B.TABLESPACE_NAME (+)
    ORDER BY 1;
    Steeve Bisson
    EMail: steeve_2@videotron.ca
    London
    Thanx for the help: it works fine!
    Fiona
