I need to use SQL*LOADER and possibly the import and
export utilities to load data. I would like to
install
these utilities. Does anyone know on which Oracle
CD I can find these utilities. I already have forms
and reports 6i installed on my machine and only want
to add the other utilities. I do not wish to install
more than necessary. I only want the SQL*LOADER,
import and export utilities. Can someone tell me how
to accomplish this without installing a lot of
unnecessary programs.
Re: installing sql loader on existing oracle client
Originally posted by rajvendra I need to use SQL*LOADER and possibly the import and
install
You should have the Oracle Client on your PC if Forms is installed already. Get hold of the database server CDs and perform a custom install. This should allow you to choose just SQL*Loader from the utilities list. This worked for me some time ago with the 8i CDs.
In the Win 8i client I'm using (installed with all options) I find sqlldr, imp and exp. So I conclude they are on the Client CD. You'd need to select "custom installation" to be able to select just the options you want.
