Thread: Help required in tuning the Sql for hierarchical query
    California
    The below query using the order by is taking lot of time to execute,
    when the order by is ignored then the query execution is fast
    can any one help me to tune this query using the order by clause
    SELECT node_id ,
    (SELECT node_name
    FROM tree
    WHERE level = 1 -- This will fetch the account value
    START WITH node_id = sa.node_id
    CONNECT BY PRIOR parent_node_id = node_id) AS account,
    SELECT node_id ,
    (SELECT node_name
    FROM tree
    WHERE level = 2 -- This will fetch the company value
    CONNECT BY PRIOR parent_node_id = node_id) AS company,
    SELECT node_id ,
    (SELECT node_name
    FROM tree
    WHERE level = 3 -- This will fetch the state value
    CONNECT BY PRIOR parent_node_id = node_id) AS state,
    SELECT node_id ,
    (SELECT node_name
    FROM tree
    WHERE level = 4 -- This will fetch the region value
    CONNECT BY PRIOR parent_node_id = node_id) AS region,
    c.short_name AS id,
    c.name AS title, r.name AS studentid,
    r.last_name || ', ' || r.first_name AS studentname,
    r.email AS email, s.phone AS phone,
    DECODE (s.e_date,
    TO_DATE ('01-Jan-1900'), TO_DATE (''),
    s.edate_key
    ) AS edate,
    DECODE (s.ldate,
    s.ldate
    ) AS ldate,
    rc.field_1 AS hiredate, rc.field_2 AS licensedate,
    rc.field_3 AS datepassed,
    DECODE (rc.custom_field_4,
    'UNKNOWN', '',
    rc.custom_field_4
    ) AS lnumber
    FROM admin sa,
    hierarchy ch,
    studentcourse s,
    studentregistration r,
    registration rc,
    course c
    WHERE sa.admin_key = 'UdonmortonSUB2533274790497513'
    AND ch.subdomain_key = sa.subdomain_key
    AND s.subdomain_key = ch.subdomain_key
    AND r.student_registration_key = s.student_registration_key
    AND rc.registration_custom_key = s.registration_custom_key
    AND c.course_key = s.course_key
    AND s.edate >= TO_DATE ('01-Jan-2003')
    AND s.edate <= TO_DATE ('30-Jan-2003')
    AND s.ldate >= TO_DATE ('01-Jan-2003')
    AND s.ldate <= TO_DATE ('30-Jan-2003')
    AND c.name LIKE '%'
    ORDER BY accountname, id, studentid -- this order by is taking lot of time to execute
    How can I tune the above query with order by clause since the order by clause is required
    Thanks in advance
    Honda
    [COLOR=orangered][COLOR=royalblue][COLOR=royalblue][COLOR=royalblue]
    Aug 2001
    That means sorting is slow . Sorting starts when Oracle gets all required rows into memory..
    1. bigger Sort_area_size ??
    2. or Pga_agegate_size ?? depending on version
    3. temp tablespace
    Can you post explain plan
    Raghu
    Oct 2002
    why even have this line?
    AND c.name LIKE '%'
    - Cookies
    Oct 2002
    does this do the same thing?
    PHP Code:
    select     node_id,
    max(decodelevel1node_nameNULL)) as account,
    max(decodelevel2node_nameNULL)) as company,
    max(decodelevel3node_nameNULL)) as state,
    max(decodelevel4node_nameNULL)) as region,
    idtitlestudentidstudentnameemailphoneedateldate,
    hiredatelicensedatedatepassedlnumber
    from
    (SELECT
                node_id
    t.level,
    t.node_name,
    c.short_name AS id
    c.name AS titler.name AS studentid
    r.email AS emails.phone AS phone
    replace(s.e_date'01-Jan-1900''') AS edate
    replace(s.ldate'01-Jan-1900''') AS ldate
    rc.field_1 AS hiredaterc.field_2 AS licensedate
    replace(rc.custom_field_4'UNKNOWN''') AS lnumber
            FROM
                admin sa
    hierarchy chstudentcourse s
    studentregistration rregistration rccourse c,
    tree t
            WHERE sa
    .admin_key 'UdonmortonSUB2533274790497513'
    AND ch.subdomain_key sa.subdomain_key
    AND s.subdomain_key ch.subdomain_key
    AND r.student_registration_key s.student_registration_key
    AND rc.registration_custom_key s.registration_custom_key
    AND c.course_key s.course_key
    AND s.edate >= TO_DATE('01-Jan-2003'
                AND
    s.edate <= TO_DATE('30-Jan-2003'
                AND
    s.ldate >= TO_DATE('01-Jan-2003'
                AND
    s.ldate <= TO_DATE('30-Jan-2003'
                AND
    sa.node_id t.node_id)
    group by node_ididtitlestudentidstudentnameemailphoneedateldate,
    order by accountname
    idstudentid
    - Cookies
    California
    No the above query will not serve the purpose, since for the given child existing at the district level i need to fetch those parents from the hierarchy table hence i need to have the hhierarchy connect by clause
    and the explain plan is as below
    Operation Object Name Rows Bytes Cost Object Node In/Out PStart PStop
    SELECT STATEMENT Optimizer Mode=CHOOSE 1 35
    SORT ORDER BY 1 424 35
    NESTED LOOPS 1 424 33
    NESTED LOOPS 1 293 31
    NESTED LOOPS 1 238 29
    NESTED LOOPS 1 165 27
    HASH JOIN 4 304 15
    TABLE ACCESS BY INDEX ROWID ADMIN 4 168 2
    INDEX RANGE SCAN ADMIN_KEY 4 1
    TABLE ACCESS FULL HIERARCHY 18 K 625 K 12
    TABLE ACCESS BY INDEX ROWID STUDENTCOURSE 5 K 506 K 3
    INDEX RANGE SCAN SC_SUB_ENROLL_CRS_PCT_X_A 5 K 2
    TABLE ACCESS BY INDEX ROWID COURSE_0_A 278 K 19 M 2
    INDEX UNIQUE SCAN XPKCOURSE_0_A 278 K 1
    TABLE ACCESS BY INDEX ROWID REGISTRATION 551 K 28 M 2
    INDEX UNIQUE SCAN XPKREGISTRATION 551 K 1
    TABLE ACCESS BY INDEX ROWID STUDENTREGISTRATION 1 M 132 M 2
    INDEX UNIQUE SCAN XPKSTUDENTREGISTRATION 1 M 1
    TheD c.name LIKE '%' is required to fetch all the courses based on the filter provided in the paramter, for ex if i give a specific course then c.name ='course_name 'else if in the SQL i want all tha courses then the sql to get all the courses should include and c.name LIKE '%'
    Regds,
    honda
