    Mar 2004
    IA USA
    how to disable the ampersand in sql script?
    Hi DBAs,
    There are some ampersands before the data which should be inserted into the database in some of the scripts. When I run them, the system
    always prompted to input data. This is the default behavior.
    How can I disable the default ampersand functionality?
    Lily
    Colorado Springs
    set define off
    David Aldridge,
    "The Oracle Sponge"
    XM Satellite Radio
    Washington, DC
    Oracle ACE
    Birmingham, UK
    set scan off does the job too
