    Jan 2004
    Unhappy re: need help with ORA-00947
    hi! ,
    I am using sqlplus ...
    I have a procedure x in user abc.
    I am trying to create the same procedure x in user jkl.
    I selected the text from user_source into notepad and saved it
    as a sql file.
    The formatting got all screwed up so I tried my best to format it
    and run the sql file from the sqlplus prompt of user jkl.
    I am geting the following errors ..
    SQL> @c:\tsrtrafficdtalinking.sql
    Warning: Procedure created with compilation errors.
    SQL> show errors
    Errors for PROCEDURE TSRTRAFFICDATALINKING:
    LINE/COL ERROR
    133/20 PL/SQL: SQL Statement ignored
    133/36 PL/SQL: ORA-00947: not enough values
    167/23 PL/SQL: SQL Statement ignored
    167/39 PL/SQL: ORA-00947: not enough values
    211/23 PL/SQL: SQL Statement ignored
    211/39 PL/SQL: ORA-00947: not enough values
    223/23 PL/SQL: SQL Statement ignored
    223/39 PL/SQL: ORA-00947: not enough values
    262/26 PL/SQL: SQL Statement ignored
    262/42 PL/SQL: ORA-00947: not enough values
    275/26 PL/SQL: SQL Statement ignored
    275/42 PL/SQL: ORA-00947: not enough values
    How do I rectify this ???
    Is there any where of directly creating the procedure in user jkl
    without having to create a sql file and then running the sqlfile ..??
    thanks,
    harish
    thanks,
    harish
    Jan 2002
    Up s**t creek
    Can you post some of the statements creating the errors (as shown by the error line code), It sounds like some typos have been made during the reformatting.
    Jim
    Oracle Certified Professional
    "Build your reputation by helping other people build theirs."
    "Sarcasm may be the lowest form of wit but its still funny"
    Click HERE to vist my website!
    Jan 2004
    Unhappy PROBLEM WAS ....
    FYI,
    the problem was an insert statement in the code that was inserting four values into five columns ....
    i thought it was a formatting error
    thanks,
    harish
