Results 1 to 7 of 7
    Nov 1999
    help with PL/SQL
    I am trying to run a PL/SQL to get the table_name , num_rows from user_tables and count(*) for each table and if the difference between num _rows and count(*) for that table is greater than 10000 then I want to display it .
    declare
    tab varchar2(100);
    a number;
    b = 2 number ;
    c number
    loop
    b:= b +1;
    SELECT table_name into tab FROM user_tables where rownum < a;
    SELECT NUM_ROWS INTO b FROM USER_TABLES WHERE TABLE_NAME = 'tab';
    select count(*) into c from 'tab';
    if b - c > 10000 then
    dbms_output.put_line ('tab' , b , c );
    exit when b = 30;
    end loop;
    end;
    Please let me know what is wrong with this .
    You need to use dynamic sql to pass table_name.
    Example:
    CREATE OR REPLACE procedure tamil_upd_sbl_tbls_rowcount as
    p_rowcount Number := 0 ;
    p_tablesize Number := 0 ;
    stmt_str varchar2(4000) ;
    p_new_run_id Number := 0 ;
    p_tsname varchar2(30);
    p_ext Number := 0 ;
    ---- execute immediate 'truncate table tamil_dba_siebel_tables';
    ---- get maximum run_id from tamil_dba_siebel_tables
    execute immediate
    'alter session set optimizer_mode = choose ' ;
    select max(run_id) into p_new_run_id
    from tamil_dba_siebel_tables;
    p_new_run_id := nvl(p_new_run_id,0) + 1; ---- increment by 1
    for ctab in ( select table_name as tabname
    from user_tables
    ) Loop
    -- dbms_output.put_line(ctab.tabname||' '|| ctab.tabname) ;
    stmt_str := 'select /*+ full(a) parallel(a,8) */ count(*) from '||ctab.tabname ||' a';
    -- dbms_output.put_line(stmt_str);
    execute immediate stmt_str into p_rowcount ;
    stmt_str := 'select bytes , tablespace_name, extents from user_segments where '
    ||'segment_name = :X1 ' ;
    execute immediate stmt_str into p_tablesize, p_tsname, p_ext using ctab.tabname ;
    ---- first, insert tables' details
    insert into tamil_dba_siebel_tables
    (run_id, object_name, object_type, row_count, bytes, run_date, tablespace_name, extents)
    values
    (p_new_run_id, ctab.tabname, 'TABLE', p_rowcount, p_tablesize, sysdate, p_tsname, p_ext);
    end loop ;
    ---- next, insert indexes' details
    select p_new_run_id, segment_name, 'INDEX', 0, bytes, sysdate, tablespace_name, extents
    from user_segments
    where segment_type = 'INDEX' ;
    commit;
    exception when others then
    dbms_output.put_line('Error encounterd ' );
    end;
    The above procedure does row counts and store in a table.
    Tamil
    Aug 2003
    Southern Jersey
    Re: help with PL/SQL
    declare
    tab varchar2(100);
    a number;
    b = 2 number ;
    c number
    loop
    b:= b +1;
    exit when b = 30;
    end loop;
    end;
    Let's start with...everything?! Not to be destructive, but I can not correlate what you say you're trying to do with what that code is doing whatsoever.
    First, you do a loop and increment the variable 'b', which you then stomp on later on with the line "select num_rows into b from user_tables..." -- and I'm not even sure what you're attempting to accomplish with that line; it asks where table_name = 'tab', and obviously you can only have zero or one tables with the exact name 'tab', maybe you mean where table_name LIKE 'tab%' or maybe you think that 'tab' will use the variable tab, which it won't.
    Now you exit when b = 30, which may or may not ever happen given that you stomp its value.
    I think you might need to more clearly state your goal, because from your code I can not even derive it; but it looks like you want to do more than what you say? What are you doing a difference for? What is the actual purpose of 'b'? Also, why are you selecting table names where rownum < a?
    Nov 1999
    The objective is to find tables that need to be analyzed . I need to find tables whose num_rows in user_tables are different from their count(*) by more than 10000
    greenwich.ct.us
    ...or in other terms, how many lines of code can you write to replace existing functionality in Oracle...
    gather stale
    marist89@yahoo.com
    http://marist89.blogspot.com/
    Get Firefox!
    Nov 1999
    Got it , Here are the steps
    1) create table test_table (id number , table_name varchar2(30) , num_rows number , cnt number ) ;
    2) create table test2 select table_name , num_rows from user_tables;
    3) insert into test_table (table_name , num_rows ) select (table_name , num_rows ) from test2;
    4 ) commit;
    5) create sequence test_seq nomaxvalue nocycle ;
    6) update table test_table set id = test_seq.nextval;
    7 ) commit;
    8 ) declare
    v_table_name VARCHAR2(30);
    v_cnt number ;
    v_counter number := 1;
    for v_counter in 1.. 100 loop
    select table_name into v_table_name from test_table where id = v_counter;
    dbms_output.put_line (v_table_name ) ;
    stmt_str := 'select count(*) from '||v_table_name ||'';
    execute immediate stmt_str into v_cnt ;
    update test_table set cnt = v_cnt where table_name = v_table_name ;
    dbms_output.put_line(v_cnt);
    commit;
    end loop;
    end ;
    9 ) select table_name from test_table where cnt - num_rows > 10000 ;
    Thats all , It works
    Thanks guys
    Lake Worth, FL
    You could also use these scripts:
    http://www.ixora.com.au/scripts/query_opt.htm
